william(at)wbliss.co.uk Guest
Posted: Sun Oct 28, 2018 1:51 pm Post subject: LED lights intercom interference - Ferrite needed? |
Hi all
I have installed bright LED's into the cowling for improved visual
conspicuity. When the engine is not running I now have audible
breakthrough white noise through the headsets in time with the Skyflash
strobe light (which is mounted on the tail). I have had no problems with
the strobe system up until now. While flying the white noise was
continuous but I was able to partially stop it by altering the intercom
squelch. I then found I had no interference on one frequency but still
had lots on another frequency. Radio communications do not seem to be
affected. The LED and Strobe circuits run off separate contact breaker
switches. Radio and Transponder are Trig which work ok up to now.
There is no high frequency noise suppresion in the LED wiring. I will
try running the power cable through a ferrite ring close to the LED
unit. Any suggestions?
William Bliss G-WUFF Mono
Burrilla
Posted: Mon Oct 29, 2018 12:30 am Post subject: LED lights intercom interference - Ferrite needed? |
Sounds like you’ve disturbed something in installing the new wiring.
First thing I would check is that everything is earthed to a common Earth Bus and that all the connections are tight.
How are you powering the new LED? some converters that drop the 12V to LED voltages, 1.2 - 1.4 volt, produce noise from a switching circuit. does the noise stop if you pull the LED breaker?
Alan
Quote: | On 28 Oct 2018, at 21:43, William Bliss <william(at)wbliss.co.uk> wrote:
Hi all
I have installed bright LED's into the cowling for improved visual conspicuity. When the engine is not running I now have audible breakthrough white noise through the headsets in time with the Skyflash strobe light (which is mounted on the tail). I have had no problems with the strobe system up until now. While flying the white noise was continuous but I was able to partially stop it by altering the intercom squelch. I then found I had no interference on one frequency but still had lots on another frequency. Radio communications do not seem to be affected. The LED and Strobe circuits run off separate contact breaker switches. Radio and Transponder are Trig which work ok up to now.
There is no high frequency noise suppresion in the LED wiring. I will try running the power cable through a ferrite ring close to the LED unit. Any suggestions?
r.vogel(at)ggs.ch Guest
Posted: Mon Oct 29, 2018 2:21 pm Post subject: LED lights intercom interference - Ferrite needed? |
Hi William
I have the same problem caused by the switching voltage regulator inside
the LED spot
light in the cowling. One ferrite core was not enough to fix this problem.
I will test an EMI Suppression Filter, close to the LED, as next step
and will inform you about the result.
Ruedi Vogel
Am 28.10.2018 um 22:43 schrieb William Bliss:
Quote: |
Hi all
Ruedi Vogel, 3380 Wangen a.A.
