billykay1(at)AOL.COM Guest
Posted: Fri Oct 13, 2006 5:40 pm Post subject: engines |
Hello,
Has anybody (besides me) considered putting a 4 cylinder lyc (or derivative) in the 10?
Billy Kehmeier
tail kit 574
Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more.
deruiteraircraftservices( Guest
Posted: Sat Oct 14, 2006 1:35 am Post subject: engines |
Billy,
The problem is not the power of the engine, but the weight. Hanging a four cylinder up front will leave the tail relatively heavy. This means little or no luggage, maybe one or none on the rear seat.
Stick with the original design as intended, build and fly it. If you don't like at that stage sell it and start with a clean sheet ofpaper and design your own.
flysrv10(at)gmail.com Guest
Posted: Sat Oct 14, 2006 3:27 am Post subject: engines |
I really don't know why you would! If it is the fuel economy, you can run an IO- 540 nearly as economical as a four cylinder. If is the cost, you can get a really good overhaul 540 for a little more that a new X 4 cylinder. Have considered the CG?
Rob Kermanj
On Oct 13, 2006, at 9:40 PM, billykay1(at)aol.com (billykay1(at)aol.com) wrote:
[quote] Hello,
Billy Kehmeier
tail kit 574
ntribution
| [b]
wayne.e(at)grandecom.net Guest
That sounds like blaspheme to me :>}
Wayne Edgerton #40336
wv4i(at)bellsouth.net Guest
Posted: Sat Oct 14, 2006 5:07 am Post subject: engines |
4 cyl eng in RV-10? Me. Van's. But flying off grass in FL in the summer,
probably need the bigger motor. Have some Cirrus SR-20 owners/neighbors
that can speak to this subject, although I think the wing loading on the
Cirrus is far greater than the RV-10?
Link McGarity
#40622
FD38, Wellington, FL
apilot2(at)gmail.com Guest
Posted: Sat Oct 14, 2006 6:13 am Post subject: engines |
The Cirrus uses a 210 Continental IO-360 6 cyl that is de-rated to 200
hp. That is essentially what is in Van's #2 demo. The plane was
designed to handle that engine, but there wasn't enough demand for
Vans to produce a FWF kit for it. It is a heavier engine than the Lyc
4 cyl. IO360, but not by a lot, maybe 20-30 lbs. It does take some CG
adjustment to switch between those two engines, as Cessna has done in
the 172, where they produced T41 with the Continental, and the current
172 with the Lyc, and the early 172 with O-300 Cont 145 hp. Mooney's
201 vs 231 is similar, but the 231 has both heavier Cont engine and wt
of turbo charger install up front, making it more nose heavy.
On 10/14/06, Link McGarity <wv4i(at)bellsouth.net> wrote:
Link McGarity
#40622
ajhauter(at)yahoo.com Guest
Posted: Sat Oct 14, 2006 10:53 am Post subject: engines |
The new Superior XP-400 rated at 220 HP is worth looking into if the CG issues can be addressed. What are you considering?
_________________________
Hello,
the 10?
Billy Kehmeier
tail kit 574
LIKE2LOOP(at)aol.com Guest
Posted: Sat Oct 14, 2006 1:59 pm Post subject: engines |
In a message dated 10/14/2006 2:56:18 PM Eastern Standard Time, ajhauter(at)yahoo.com writes:
| Quote: | Has anybody (besides me) considered putting a 4 cylinder lyc (or derivative) in
the 10?
I am currently flying a Cessna 170 with a 6 cylinder Continental 0-300. I would NEVER go back to a horizontally opposed 4 cylinder engine. SOOOOoooooo much smoother. Less vibration and ultimately less stress on the internal parts if you do the math as to how much horse power each cylinder has to put out. If you want great economy, just throtle the IO-540 back to 50% power and you will save tons on fuel and still go faster then most spam cans with dome shaped rivets in the breeze. If you change the engine, you then have to redesign the entire front end and deal with the W & B issues that are significant. What is the value of trying to use a 4 cylinder engine? Less reserve power, less performance???
Steve
DO NOT ARCHIVE
Stephen Blank #40499
766 SE River Lane
Port St. Lucie, FL 34983
772-475-5556 cell - evenings and weekends
johngoodman
Posted: Sun Oct 15, 2006 4:37 pm Post subject: Re: engines |
This has been a good discussion. I have also considered smaller engines, but my motivation has been more towards alternative fuels. I love the idea of a Turbo, but that would probably mean 100LL. My concern is that 100LL may be a dying product (can you still play the old VHS tapes of your kids growing up?).
Another advantage of a smaller, lighter engine is a larger alternator and maybe an air conditioner compressor on the engine. Moving the batteries and ELT forward could solve CG issues as well.
I am definitely listening to the guys who say a 6 runs smoother and I will probably go for the 540, but there is no harm in looking.
[quote="LIKE2LOOP(at)aol.com"]In a message dated 10/14/2006 2:56:18 PM Eastern Standard Time, ajhauter(at)yahoo.com writes:
the 10?
Steve
DO NOT ARCHIVE
Stephen Blank � #40499
766 SE River Lane
coop85(at)bellsouth.net Guest
Posted: Sun Oct 15, 2006 4:58 pm Post subject: engines |
John,
I couldn't agree more that looking is half the fun, and it's free!
However, here's some thought's on your comments about the lighter engine.
Adding the air conditioner compressor to an already somewhat anemic engine
could lead to disappointing performance. I have no clue what the actual
increase in load would be, but I know I can tell when the car's A/C kicks
in. As for the battery, there's not a whole lot of options to move the
battery forward, other than all the way to the firewall. It might work, but
there's limited real estate up there already and the move may be further
forward than you want.
Just some thoughts to kick around (or out the door )
Marcus
Happy flying the IO-540 model.
robin1(at)mrmoisture.com Guest
Posted: Sun Oct 15, 2006 6:40 pm Post subject: engines |
John,
Some day you will want or need to sell your -10. That will be when you find out how expensive "alternate" engines really cost. I am all for the concept of different engine choices (and applaud all who try) but one day you will have to convince a buyer to purchase your alternate choice and regardless of how nice you built the rest of the plane you should expect to shave $20-30K off a comparable plane while at the same time limiting the total number of buyers to ~20% of the original pool of prospects. (These numbers are HIGHLY scientific based on all recent -10 sales with alternate engines)
When considering the additional time & expense it may take to get an alternate engine actually flying and that will far outweigh any potential savings.
A note not covered on the recent discussion “RV7a v. Legacy FG v. Glassair SII FT” not mentioned when comparing each model and their respective traits is the significant increase in build time between the Vans kits and the other choices. Everyone concedes that the other choices are beautiful planes but I would prefer spending the extra 2000+ build hours actually flying.
Robin
AV8ORJWC
Posted: Sun Oct 15, 2006 10:25 pm Post subject: engines |
Robin, this is out of context but where did you pull your statement "~20% of the original pool of prospects. (These numbers are HIGHLY scientific based on all recent -10 sales with alternate engines)"?
I am not aware of one single flying alternate engine RV-10 except N210RV. That is only an alternate to the Lycoming (being a Continental). No science used in this conclusion. I'm baffled.
John Cox
________________________________________
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Sunday, October 15, 2006 7:40 PM
Subject: RE: Re: engines
John,
A note not covered on the recent discussion "RV7a v. Legacy FG v. Glassair SII FT" not mentioned when comparing each model and their respective traits is the significant increase in build time between the Vans kits and the other choices. Everyone concedes that the other choices are beautiful planes but I would prefer spending the extra 2000+ build hours actually flying.
Robin
Posted: Mon Oct 16, 2006 4:29 am Post subject: engines |
You aren't going to find many 4 or 6 cyl engines as smooth as your
O-300. The I/O-540 certainly is not nearly as smooth. But with a well
balanced prop, at more than taxi power you really won't notice that
much difference flying along, whether behind a 4 or 6 running
smoothly.
On 10/14/06, LIKE2LOOP(at)aol.com <LIKE2LOOP(at)aol.com> wrote:
in
the 10?
Steve
DO NOT ARCHIVE
766 SE River Lane
Posted: Mon Oct 16, 2006 6:35 am Post subject: engines |
Well said John!
Thank you!
John G. 409
Do Not archive
| Quote: | From: "John W. Cox" <johnwcox(at)pacificnw.com>
Date: Sun, 15 Oct 2006 23:23:11 -0700
John Cox
John,
engines)
savings.
Robin
james.k.hovis(at)gmail.co Guest
Posted: Mon Oct 16, 2006 7:16 am Post subject: engines |
I wouldn't worry too much about using a lighter, less performing engine in the 210 - 230 HP range if you can live with a little loss of performance. Weight and balance is fairly easy to deal with, move the battery forward to the firewall and make provisions to add lead ballast. The firewall is typically pretty stout and should be able to handle the loading from the battery and a few pounds of lead. I would wait to add any ballast up front until after an empty aircraft weight and balance check is done. If the CG is outside limits, then add ballast as needed. Do check with Van's about ballast installation on the firewall if needed. You could end up with an aircraft with a lighter empty weight which translates into more useful load or more weight to add more avionic goodies.
Everything in aircraft design and performance is a trade-off, give up some top-end performance and get a few more pounds for other things. Van's specs for 260 vs. 210 HP don't look too bad. At gross you lose about 10MPH of speed, but climb rate suffers more at about 300 fps loss. However, at 1,150 fps, it still climbs better than most spam-cans weighing 2,700 lbs....
JKH
On 10/16/06, John Gonzalez <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote: [quote]--> RV10-List message posted by: "John Gonzalez" < indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)>
Well said John!
Thank you!
John G. 409
Do Not archive
| Quote: | the concept of different engine choices (and applaud all who try) but one
engines)
savings.
Robin
Tim(at)MyRV10.com Guest
Posted: Mon Oct 16, 2006 8:09 am Post subject: engines |
Man, if people want to fly slow planes with poor performance at
altitude, it would he a heck of a lot cheaper to just buy a
spotless Cherokee/Sundowner/Sierra or something like that.
The RV-10 does great with a plain IO-540, but I sure wouldn't
have wanted to be climbing around on my flights this past week
with a 4-cyl 200hp engine. The RV-10 is well suited for 8000-14000'
crusing, but why put an anemic 4-cyl in it and wreck a beautiful
plane? The 210 continental is a nice enough engine, but again,
where are the real significant benefits...more build time,
more mods.
If you want MoGas, go with the O-540 then. For the 4-cyl fans
though, I can only hope that someone actually DOES this soon
so that people can learn how disappointing it would be...and
it can deter others from going down the road to a probable
mistake.
I'll put it this way.... An IO-540 is not too much engine
for the RV-10, and it's not too little. Climbing out of
LOE (5T6), we were getting 800-900fpm in standard climb
config. Isn't that slow enough? Putting more HP isn't
really necessary though either. Only a rare handful of
people would ever even think about cruising the RV-10
at altitudes above 18,000'. I think Van's actually got
it very right on the engine...oh, and the plane too.
Just got back from LOE....put on over 20 hours and over
3000nm this week. There's going to be one heck of a trip
story to see when I can get it posted.
Oops, almost forgot: More specs coming, but how does
160-163 kts on 8.6gph sound? 4-cyl.....HA!
James K Hovis wrote:
| Quote: | I wouldn't worry too much about using a lighter, less performing engine
avionic goodies.
JKH
On 10/16/06, *John Gonzalez* <indigoonlatigo(at)msn.com
<mailto:indigoonlatigo(at)msn.com>> wrote:
indigoonlatigo(at)msn.com <mailto:indigoonlatigo(at)msn.com>>
Well said John!
Thank you!
John G. 409
Do Not archive
<mailto:johnwcox(at)pacificnw.com>>
>Reply-To: rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
>To: <rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>>
<johnwcox(at)pacificnw.com <mailto:johnwcox(at)pacificnw.com>>
statement "~20%
scientific
N210RV.
>John Cox
<mailto:owner-rv10-list-server(at)matronics.com>
<mailto:owner-rv10-list-server(at)matronics.com>] On Behalf Of Robin Marks
>John,
all for
but one
choice and
expect to
limiting the
(These
alternate
>engines)
potential
>savings.
between the
choices
>Robin
AV8ORJWC
Posted: Mon Oct 16, 2006 8:25 am Post subject: engines |
A reduction of 260 to 210 is a 19.2% reduction in BHP. To maintain the same robust HP/Weight and not have an anemic performer, then the gross weight would have to be reduced to 2208 pounds.
For simpletons like me that’s 492 pounds of offloaded fuel or passengers cause there just is not that much difference in powerplant weight saved on the empty weight side of the equation. I guess that means a RV-9 with a four banger. Now where is my math supporting a more anemic engine. Oh, yeh – four cylinders instead of six, Fuel Consumption. Oh, no – I forgot about pulling the throttle back and running a more anemic power output. Thus saving the throttle for the quick go arounds and climbouts to avoid weather.
Not all tradeoff are equal in logic. This reminds me of 17 friends who embraced the idea of putting ½ VW engines (yes two cylinders) in Nieuport replicas. I pointed out that with a 254 pound body weight the thing might not fly. He bailed on the project and watched the first prototype crash from lack of power. Conclusion, Van has done a pretty good job with the mission statement of the 4 place RV-10 with a six banger. Now with this logic is there anyone willing to consider a 9 cylinder, 360 hp radial? Kimball did it to satisfy those frustrated four cylinder owners with Pitts.
JWC
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James K Hovis
Sent: Monday, October 16, 2006 8:16 AM
Subject: Re: Re: engines
JKH
Well said John!
Thank you!
John G. 409
Do Not archive
>From: "John W. Cox" <johnwcox(at)pacificnw.com (johnwcox(at)pacificnw.com)>
>Reply-To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
>To: <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
>--> RV10-List message posted by: "John W. Cox" <johnwcox(at)pacificnw.com (johnwcox(at)pacificnw.com)>
>John Cox
>From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)
>[mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Robin Marks
>John,
>engines)
>savings.
>Robin
[quote] [b]
GRANSCOTT(at)aol.com Guest
Posted: Mon Oct 16, 2006 9:01 am Post subject: engines |
Genrally putting the battery on the firewall will shorten the life of a battery plus if you do put the battery on the firewall, you should consider creating an easy access to it's location...having the battery close to the starter may not be a bad thing as there is less line lose in the distance from the firewall to the starter as opposed to a location in the rear of the aircraft.
P
Posted: Mon Oct 16, 2006 9:13 am Post subject: engines |
I think you're slightly missing the point. If you have two identical
airframes sitting side-by-side and the only difference is one has a 210hp
engine and the other has a 260, you WILL see differences in performance. To
me, it's really a matter of the individual builder to decide what type of
mission he/she wishes to fly. According to Van's data, you lose about 10 mph
in flight speeds, lose 300 fps in climb rate but gain about 125 miles in
range (implying better fuel efficiency) (I'd like to see these numbers
verified, but Van's has a pretty good track record of meeting the
performance figures they publish). Sure, you can back off power in cruise
with an O-540 and match the range figures for a 210hp engine, what's your
trade-off when you do so? Speed. Personally, I'd rather have the horsepower
reserve from a big engine and fly it more economically, say at 165 mph or
so. Going fast isn't that big of a deal to me, a 100kt C-150 is still
quicker than a car for most "long distance" trips. If I can get a hold of a
210-230hp engine that is significantly cheaper than the 260hp Lycs while
weighing equal to or less than the "stock" engine, I will seriously consider
it. Having to do some additional engineering and fabrication for a
"non-stock" engine shouldn't be a killer either. As I point out you could
end up with a lighter installation which has it's own benefits to the
airplane's mission. However, I don't see how a TIO-360 installation would be
cheaper than and in then end, more reliable than the straight O-540. Don't
think that I'm endorsing automotive installations, it is RARE that a 260 hp
car engine will weigh less than an O-540 once you consider reduction drive,
radiator, etc. needed for such installations.
Again, my main point, if you can live with a lower performing airplane, a
smaller engine might be better for YOU if the resulting mission capabilities
conform to the mission you wish to have. As a simple IFR family truckster, a
210 hp engine might not be too bad.
JKH
For simpletons like me that's 492 pounds of offloaded fuel or passengers
JWC
*From:* owner-rv10-list-server(at)matronics.com [mailto:
owner-rv10-list-server(at)matronics.com] *On Behalf Of *James K Hovis
*Sent:* Monday, October 16, 2006 8:16 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Re: engines
JKH
On 10/16/06, *John Gonzalez* <indigoonlatigo(at)msn.com> wrote:
Well said John!
Thank you!
John G. 409
Do Not archive
>From: "John W. Cox" <johnwcox(at)pacificnw.com >
>To: <rv10-list(at)matronics.com>
sschmidt(at)ussynthetic.c Guest
Posted: Mon Oct 16, 2006 9:39 am Post subject: engines |
Six Cylinders Truck - Four Cylinders Suck!
(I have the same battle with the snowboarders but in that case, 4 edges
truck and two edges suck)
Go fly in Van's 410RV and then make your decision.
Scott Schmidt
