order of assembly for cooling duct, radiators and hoses
dpark748(at)me.com
PostPosted: Sun Nov 18, 2018 12:09 pm    Post subject: order of assembly for cooling duct, radiators and hoses Reply with quote
If it helps, i fitted Nevs cowls, with his help.
It was a straight swap with the cooling system in place. Only had to re-seal with rubber sheet around edges and bottom of radiator
Dave Park
On 18 Nov 2018, at 18:48, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
I’m trying to figure out the optimum sequence of assembly (or even a sequence that is possible!) for the various cooling items on my XS monowheel, with Neville Eyre cowl and Rotax 912S.
I’ve listed which things need to be done before others - eg:
The long bolts and spacers securing the oil cooler will be much easier to fit before the duct is mounted to the firewall.
The bolts holding the duct sides to the CD4/CD5 brackets are obstructed by the oil cooler and water radiator, so need to be fitted first
The hose clips for the oil cooler connexions are hidden by the water radiator so need to be fitted before the radiator is installed (or can I get at them from the aft side?)
The hose clips for the water radiator connexions will be out on top of the duct so should be fitted before the duct is installed (or can I get at them by reaching down through the engine mount?)
. . . and so it goes on . . .
Has anyone got a sequence of assembly that works? Or on the other had, can anyone offer suggestions about what definitely NOT to do?
in friendship
Rowland
