Snot valve, constantly builds pressure. Normal/Not?
cjpilot710(at)aol.com
PostPosted: Wed Nov 21, 2018 10:26 am    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Brandon, To disassemble the check valves does take some muscle. (I think there are 4 chinamen on a 4-foot bar wrench tightening these things sometimes). You can get a kit from Doug Sapp to replace the rubber (the best kind) in the check valves. A lot of times there is corrosion there and you may need a whole new check valve but clean it up real good. Most of the time its just the rubber that's bad. IAC clean it up good then I coat mine with a thin layer of boat axle grease. (That seems to help alot on the corrosion issue).
Jim "Pappy" Goolsby
bmsim
PostPosted: Wed Nov 21, 2018 11:06 am    Post subject: Re: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Thank you very much!! I'll disassemble again and get to work rebuilding. I have the kits with the rubber washers, etc. already, so hopefully I can get them apart and installed.
Thanks again!
bwade154(at)yahoo.com
PostPosted: Mon Nov 26, 2018 10:55 am    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
some of toughs air valves and cylinders have set screws that are partially covered in paint if you take them apart without removing the set screw the threads are ruined.
On ‎Monday‎, ‎November‎ ‎26‎, ‎2018‎ ‎11‎:‎39‎:‎59‎ ‎AM‎ ‎EST, Warren Hill <hill(at)doctor-hill.com> wrote:
--> Yak-List message posted by: Warren Hill <hill(at)doctor-hill.com (hill(at)doctor-hill.com)>
Jill Gernetzke can also repair/rebuild them, but it takes the force of a pneumatic hammer to get them apart.
Warren Hill
On Nov 22, 2018, at 10:53 PM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
--> Yak-List message posted by: Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>
CJ or YAK? The YAK check valves that have been in use for a few bears are a bitch to get apart. I personally think they use epoxy on the groves. It takes a vice and a torc to get them apart on occasion. Be prepared to replace all of the guts in that case.
You can just send them to Cliff Coy to rebuild with Parker air system parts. They hone the case to do that.
Or you could replace the with Dzongkha Sapps Kit.
Doc
> On Nov 21, 2018, at 11:37 AM, bmsim <bmsim(at)hotmail.com (bmsim(at)hotmail.com)> wrote:
> --> Yak-List message posted by: "bmsim" <bmsim(at)hotmail.com (bmsim(at)hotmail.com)>
> Thanks guys!
> I have rebuild kits and filter for the T assembly. For the individual sides, do the check valves just screw apart? I disassembled the T the other day and tried to take one of the valves apart but it was so hard to turn that it appears to need a vise. I didn't know if that's normal or if I'd be tearing something up, so I stopped until I could ask.
> Should the individual sides of the T assembly require a vise to disassemble, or am I missing something on how to disassemble?
> Brandon
> http://forums.matronics.com/viewtopic.php?p=485478#485478
httpbsp; ===================
http://www.matronics.com/Navigsp; - MATRONICS WEB FORUMS -
http://wiki.matr========================
