davidjoyce(at)doctors.org Guest
Posted: Sun Nov 25, 2018 6:18 am Post subject: Anyone has some left-over pieces of the phenolic firewall? |
Marcel, I have some firewall material and would happily post some to you. I would make tight fit plugs and judge force them in, sealing around the join with the black or brown high temp silicone sealant which plumbers merchants sell for sealing round boiler flues. Larger plugs I might be tempted to fix with a few loops (effectively stitches) of stainless wire going through 1 mm or less holes. Very small holes I would simply fill with the sealant.
Regards, David Joyce, GXSDJ
On 2018-11-24 21:42, zwakie wrote: | Quote: | | Quote: | --> Europa-List message posted by: "zwakie" <mz(at)cariama.nl (mz(at)cariama.nl)>
I am in the process of replacing the steam gauges with glass, plus redoing major portions of the electrical system as it that did not meet my standards (by a long shot).
Inevitably, I am punching 2 new holes in the phenolic firewall, and need to close of a number of holes that will no longer be used. For that I need a couple pieces of the phenolic material that the firewall is made of.
Anybody has some pieces left over from the build doing nothing but collecting dust?
Also: what's the best procedure of attaching these pieces to the phenolic firewall? I have read some posts where people where having issues with bonding to the firewall, hence this question.
Finally, as an alternative, would 1mm thick stainless bolted and sealed with E6000 offer the same level of protection?
Marcel
Marcel Zwakenberg
XS TG || 912ULS || PH-SBR
http://forums.matronics.com/viewtopic.php?p=485614#485614
lotstore.com
.matronics.com/contribution
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.com
zwakie
Posted: Sun Nov 25, 2018 7:17 am Post subject: Re: Anyone has some left-over pieces of the phenolic firewa |
Hi David,
Please check your mail, i have sent you one at davidjoyce(at)doctors.org (hopefully that one works; if not, please let me know how to contact you).
Thanks!
Marcel
_________________ Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR |
