				 Posted: Fri Nov 30, 2018 1:22 pm    Post subject: Fuse rating on AWG 20 wire with AeroLED strobes? |
				At 07:59 PM 11/29/2018, you wrote:
   	  | Quote: | 	 		  | I found the Bussmann ATC fuse specs, looks like a 7.5A fuse should be fine for brief pulses up to 8.5A from the strobes, and should also be acceptable for protecting the wire notwithstanding the AC43.13 table that says to use 5A fuse for AWG 20.  So I think I answered my own question with more research, but please advise if you see anything wrong with this approach. |
    20AWG is protected at 7A in most
    TC aircraft. But keep in mind that
    UNLIKE circuit breakers, fuses can
    be "hammered" by short duration
    transients that exceed the fuse rating.
    "Hammering" contributed to the
    sequence of events that brought
    N811HB down . . .
   https://tinyurl.com/msfmldj
    There are no risks associated with
    up-sizing the 20AWG protection to
    the next level. I'd be quite comfortable
    with 10A for your application.
				 Posted: Mon Dec 03, 2018 8:27 am    Post subject: Fuse rating on AWG 20 wire with AeroLED strobes? |
				At 10:40 PM 12/2/2018, you wrote:
   	  | Quote: | 	 		  | When you say 'unlike circuit breakers'...what do you mean?  Would the CB trip more quickly than a fuse would blow, or would it be more tolerant of what you're calling 'hammering'? |
    Both devices operated based on temperature
    rise caused by current generated heating.
    Breakers are bi-metal 'thermostats' . . . they
    trip at a calibrated temperature which is
    NOT affected by previous excursions up to the
    edge of tripping. A CB is good for thousands
    of trip cycles with very little change in
    performance.
    Fuses are pieces of metal designed to heat up
    and melt at a predictable temperature. A
    characteristic that can be tailored to a
    current flow through the 'sensing' metal.
    But operating a fuse at its recommended
    'limit' (75% of rating) produces SOME
    heating. This means that a fuse under
    normal load is already some way up the
    I(squared)R trip ladder when it is presented
    with transient 'overloads'. These little pushes
    into trip territory can cause mini-melts to
    occur in the fusible material which has the
    effect of lowering the fuse's rating. Repeated
    'hammering' will seriously compromise predictability
    of that fuse to carry normal loads.
    When N811HB lost both ignition systems on
    base to the runway, the single fuse carrying
    BOTH ignition systems had been loaded to
    more than 75% on several occasions with
    short excursions to over 100%. Compromised
    fuse predictability combined with poor
    choices in architecture to kill the
    engine.
   	  | Quote: | 	 		  | And your last statement 'there are no risks associated with up-sizing the 20 AWG protection to the next level', do you mean using a 10A fuse with 20 AWG, or are you saying to increase wire gauge to 18? |
    '20AWG protection' is classically pegged
    at 7A. Raising it to 10A or even 15A
    in this situation will stand off the 'hammering'
    effects. It is not a risky thing to do. It
    will eliminate the possibility of nuisance
    tripping.
    Given that the lights do not represent a
    critical flight system, you could leave the
    7A fuse in place and see how it goes. If
    you experience a nuisance trip, up-size the
    fuse.
    Let us know what you discover . . .
		zwakie
				 Posted: Mon Dec 03, 2018 1:34 pm    Post subject: Re: Fuse rating on AWG 20 wire with AeroLED strobes? |
				I did a little experiment on Saturday after having finalized the wiring on my strobes. Specs ask for 5A fuse, so I put a 5A fuse in and lighted up the strobes.
 Having read this post on Friday night, I was expecting the fuse to blow, but I was very surprised to see that happen so quickly (literally well within 10 seconds).
 A 7.5A fuse did hold while keeping the strobes on for more than 2-3 minutes, but to be safe I 'upped' the fuse to 10A and will 'up' the two short leads from fuse block to switch to the beefy wiring that a previous owner has put in to match the 10A fuse. I will also review the previously determined fuse-sizes for other circuits that (can possibly) carry transient loads.
 This was an educational experiment....
  _________________ Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR |
