Pietenpol-List Digest: 3 Msgs - 12/10/18
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
simmor2
PostPosted: Tue Dec 11, 2018 6:11 pm    Post subject: Pietenpol-List Digest: 3 Msgs - 12/10/18 Reply with quote
I used clamps only allowing 24 hour drying time.
- Rich
On Dec 11, 2018, at 1:39 AM, Pietenpol-List Digest Server <pietenpol-list(at)matronics.com> wrote:
Today's complete Pietenpol-List Digest can also be found in either of the
of the Pietenpol-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-12-10&Archive=Pietenpol
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-12-10&Archive=Pietenpol
Pietenpol-List Digest Archive
Total Messages Posted Mon 12/10/18: 3
Today's Message Index:
1. 05:41 PM - Help with securing rib gussets (Donald philbin)
2. 06:43 PM - Re: Help with securing rib gussets (Brian Ahrens)
3. 07:48 PM - Re: Help with securing rib gussets (Semih Oksay)
________________________________ Message 1 _____________________________________
Time: 05:41:25 PM PST US
From: Donald philbin <donaldphilbin(at)hotmail.com>
Subject: Help with securing rib gussets
Champions of the aether;
I am once again returning to building some ribs after a long absence and ho
nestly I don't have that many to go (relatively speaking). Looking at the p
lans I see the notation "nailed and glued on both sides of wing rib 1/2" 20
ga nails".
Is anyone using brass plated "Escutcheon Pins"? Stainless nails? Help!
Any an all input is appreciated.
If you wish to reach me off list my email is:
Thank you!
D.K. Philbin
________________________________ Message 2 _____________________________________
Time: 06:43:11 PM PST US
Subject: Re: Help with securing rib gussets
I used 1/4=9D brass aircraft nails from Aircraft Spruce. They were ch
eap
enough and are resistant to corrosion. A bit tricky to handle due to their
size but I found that a pair of spring action tweezers helped with that.
Of course, you could always make do with no nails at all - the only thing
they really do is hold the gussets in place while your glue dries. Using
the nails means you don=99t have to leave the ribs clamped in place w
hile
waiting for the glue to tack. I considered doing without, but I calculated
that the nails used in all of my ribs would add less than 1/4 lb to the
total weight of my Pietenpol. A good trade off in my mind, all things
considered.
Hope this helps,
Brian Ahrens
On Mon, Dec 10, 2018 at 8:44 PM Donald philbin <donaldphilbin(at)hotmail.com>
> honestly I don't have that many to go (relatively speaking). Looking at t
he
> plans I see the notation "nailed and glued on both sides of wing rib 1/2"
> 20 ga nails".
> Thank you!
> D.K. Philbin
________________________________ Message 3 _____________________________________
Time: 07:48:38 PM PST US
I used no nails at all. I used common pins nailing them lightly and removed
them after epoxy sets.
Semih Oksay
Istanbul, Turkey
> On Tue, Dec 11, 2018 at 5:45 AM Brian Ahrens <btahrens(at)gmail.com> wrote:
cheap
r
while
d
> considered.
> Hope this helps,
> Brian Ahrens
the
>> 20 ga nails".
>> Thank you!
>> D.K. Philbin
Semih Oksay
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
