Posted: Sat Dec 22, 2018 2:37 pm Post subject: Need help with replacement connector pins for KT76A |
At 09:14 AM 12/22/2018, you wrote:
| Quote: | Eewww, *those* pins. My fix, at least for experimentals, is solder, wire, and dsub connectors.
On Dec 21, 2018, at 11:11 PM, Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
The pins were discontinued by molex about a decade ago, but this guy still has stock. He’s probably the only supplier in the world, now.
https://www.mikesarcade.com/cgi-bin/store.pl?sku=CECPIN100
On Dec 21, 2018, at 21:49, jjshultz <jjshultz(at)cablemo.net (jjshultz(at)cablemo.net)> wrote:
--> AeroElectric-List message posted by: "jjshultz" <jjshultz(at)cablemo.net (jjshultz(at)cablemo.net)>
Can someone help me find a source for replacement pins for a KT76A transponder connector. I'm not sure of the name of that connector, but it is a 24-pin molded plastic unit, with two rows of 12 pins, and the pins are not cylindrical but flat.
If someone has a digikey or mouser part number that would be fantastic!
Jeff |
Two choices: I may have some original, open-barrel
crimp pins around here if you don't find them
elsewhere. I belive the connector you are wrestling
with is this one
http://aeroelectric.com/Mfgr_Data/Connectors/Molex_Waldom/Avionics_Connector_Plug_15003.jpg
and these pins
https://tinyurl.com/y7nranof
which are obsolete and rarely stocked.
I do have some of these
[img]cid:.0[/img]
Which you can purchase here:
https://tinyurl.com/y98m7ph9
or I can send you one at no charge.
I'll dig around to see if I can find the
Molex KK pins.
105.91 KB |
2213 Time(s) |
