Huosai intake tube leakage
wlannon(at)shaw.ca
PostPosted: Sun Dec 23, 2018 2:14 pm    Post subject: Huosai intake tube leakage Reply with quote
See JL2A’s post re cracking around # 4, 5 & 6 cyl intake drain ports on the Huosai engine..
If you have modified these intake tubes to accept a quick drain system without first reinforcing the tubes you are a candidate for this failure.  It is a job for a good aircraft alum. welder. Patches have to be formed and fitted to the tube and the plug boss prior to welding.
The problem arises since the Chinese weld here does not account for the sharp change in cross section between the plug boss and the very thin wall of the tube.
It is adequate (but questionable!) for the original design only. The addition of a drain fitting, or even a hose leading to a drain fitting, is enough to change the dynamics and introduce fatigue cracking around the boss.
This is not a new problem by any means but since I have done no complete restorations in recent years I had forgotten about it. I recent years I look after only my
own CJ (modified 20+ years ago) and two others with M14P engines which were properly reinforced in production. Have to admit old age may have some bearing
here as well.
Walt
