Start valve air leak
Goto page 1, 2  Next
motoadve
PostPosted: Tue Jan 15, 2019 9:23 pm    Post subject: Start valve air leak Reply with quote
Have a big air leak in the starter valve.
Where can I get a start valve re-build kit? looked at Doug Sapps site and could not find it.
www.Backcountry182.com
Cessna 182 P
CJ -6
jonboede(at)hotmail.com
PostPosted: Tue Jan 15, 2019 9:34 pm    Post subject: Start valve air leak Reply with quote
I got one from Doug. You don’t want to rebuild it, you want a new one. Just trust me on this. Wink
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=487008#487008
Robin Hou
PostPosted: Wed Jan 16, 2019 12:58 am    Post subject: Start valve air leak Reply with quote
M14p can also rebuild them. But you can flash it with WD-40 and likely to extend it's service life for a few months.
On Tue, Jan 15, 2019, 21:37 motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr) wrote:
--> Yak-List message posted by: "motoadve" <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)>
Cessna 182 P
CJ -6
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
cerveirapinto(at)gmail.co
PostPosted: Wed Jan 16, 2019 2:22 am    Post subject: Start valve air leak Reply with quote
Is the start valve the same of yak52?
Na(o) quarta, 16/01/2019, 05:30, motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> escreveu:
Cessna 182 P
CJ -6
WIKI -
If it's the same you just have to change the o ring inside. Easy to find in a car shop
Cessna 182 P
CJ -6
WIKI -
pennington.construction.i
PostPosted: Wed Jan 16, 2019 3:06 am    Post subject: Start valve air leak Reply with quote
If you own a CJ.  And you do.  All roads lead back to Doug Sapp.
Honest information.  Years of experience.
Mark (CJ Owner)
On Wed, Jan 16, 2019 at 12:30 AM motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
Cessna 182 P
CJ -6
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
dsavarese0812(at)bellsout
PostPosted: Wed Jan 16, 2019 3:44 am    Post subject: Start valve air leak Reply with quote
You would be much better off replacing it with a new one from Doug Sapp. Ask Doug if he has one with the small tab on the side. The tab is a manual release in case your battery will not activate the solenoid. VERY beneficial to have.
Dennis
On Wednesday, January 16, 2019, 6:09:40 AM EST, Mark Pennington <pennington.construction.inc.1(at)gmail.com> wrote:
Mark (CJ Owner)
Cessna 182 P
CJ -6
WIKI -
PostPosted: Wed Jan 16, 2019 3:49 am    Post subject: Start valve air leak Reply with quote
Yes, with one minor difference - sometimes. The Yak 52 air start valves all have the small manual release tab on the side. Some of the ones I've seen on the CJ's do not have the manual release tab. If you can buy one with the manual release tab, get it. Some day you just may need it.
Dennis
On Wednesday, January 16, 2019, 5:25:01 AM EST, Pedro Cerveira Pinto <cerveirapinto(at)gmail.com> wrote:
Cessna 182 P
CJ -6
WIKI -
mark.bitterlich(at)navy.m
PostPosted: Wed Jan 16, 2019 10:35 am    Post subject: Start valve air leak Reply with quote
On that note, if you have a bad starter valve that has the manual lever, and you happen to get a new valve WITHOUT the manual start lever/tab it is possible to take the housing off the old one and put it on the new one and retain the capability.
Mark
motoadve
PostPosted: Wed Jan 16, 2019 10:44 am    Post subject: Re: Start valve air leak Reply with quote
Thanks for the replies, talked to Doug Sapp, he told me how to WD40 the Starter valve and see if that fixes it , before buying another one.
Which I think its great from Doug instead of just trying to sell me one immediately.
Cessna 182 P
CJ -6
Clouddog
PostPosted: Wed Jan 16, 2019 10:57 am    Post subject: Start valve air leak Reply with quote
And that's why we love Doug Sapp. We love him like a dog..... Not like a woman. To be perfectly clear!!!
On Wed, Jan 16, 2019, 12:52 motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr) wrote:
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=487025#487025
WIKI -
wlannon(at)shaw.ca
PostPosted: Wed Jan 16, 2019 11:00 am    Post subject: Start valve air leak Reply with quote
The early production of the CJ6 air start valve unit was in all likely hood identical to the Russian unit and included the manual start tab discussed here. This tab was almost certainly intended for ground maintenance personnel use.
At some point this feature was removed in Chinese production probably for ground safety reasons and I can think of two or three scenarios here that one would definitely want to avoid.
In about 25 years of restoring and maintaining CJ’s I can not recall ever having used this.
When you overhaul the unit you have the choice of retaining or discarding this feature.
Walt
From: A. Dennis Savarese (dsavarese0812(at)bellsouth.net)
Sent: Wednesday, January 16, 2019 3:49 AM
Subject: Re: Start valve air leak
Dennis
Cessna 182 P
CJ -6
WIKI -
dougsappllc(at)gmail.com
PostPosted: Wed Jan 16, 2019 11:37 am    Post subject: Start valve air leak Reply with quote
I have a slightly different take on the situation than my good friend Walt.  Hopefully we will be able to discuss this and other more pressing world issues over some good Canadian whisky (his, not mine).
Because the QDF-1 start solenoids are widely used on the air start systems in the marine industry in China NEW QDF-1 valves are getting hard to find.  This has caused me to establish contact with the firm in China which overhauls these units for the PLAAF.  While all seem to be of high quality, some of the overhauled valves which I have received have had the levers and some have not.  However 100% of the factory NEW valves which I have received to date have had the levers.  This indicated to me that the removal of the levers is perhaps something that is done at the unit level in the PLAAF, and not at the factory which manufactures the valves.
Doug
On Wed, Jan 16, 2019 at 11:08 AM Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
Walt
Dennis
On Wednesday, January 16, 2019, 5:25:01 AM EST, Pedro Cerveira Pinto <cerveirapinto(at)gmail.com (cerveirapinto(at)gmail.com)> wrote:
Cessna 182 P
CJ -6
WIKI -
Virus-free. www.avast.com [url=#m_1918869392943923429_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
stephen.hayne
PostPosted: Mon Jan 21, 2019 7:30 pm    Post subject: Re: Start valve air leak Reply with quote
dsavarese0812(at)bellsout wrote:
...Ask Doug if he has one with the small tab on the side. The tab is a manual release in case your battery will not activate the solenoid. VERY beneficial to have.
Can someone please explain how this is used? I mean, do you move the tab, then hop in and it will start (maybe), even without enough battery to move the solenoid, but enough battery to make the shower of sparks work?? (I've read the posts from Walt/Doug - just picked Dennis' to reply too) (edited - misattributed to Dave not Dennis).
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
http://selfsynchronize.com/hayne/plane/cj6.asp
Last edited by stephen.hayne on Tue Jan 22, 2019 11:51 am; edited 2 times in total
PostPosted: Mon Jan 21, 2019 7:43 pm    Post subject: Start valve air leak Reply with quote
Pulling on the tab actuated the valve. It’s basically the same as hand-propping it when the battery is dead, except you can stand safely behind the prop and let the air turn the blades for you.
Jon
On Jan 21, 2019, at 9:38 PM, stephen.hayne <stephen.hayne(at)gmail.com> wrote:
Can someone please explain how this is used? I mean, do you move the tab, then hop in and it will start (maybe), even without enough battery to move the solenoid, but enough battery to make the shower of sparks work?? (I've read the posts from Walt/Doug - just picked Dave's to reply too)
Dr. Stephen C. Hayne, Professor, CIS, Colorado State University
666CJA
http://forums.matronics.com/viewtopic.php?p=487154#487154
stephen.hayne
PostPosted: Mon Jan 21, 2019 8:24 pm    Post subject: Re: Start valve air leak Reply with quote
All righty then - best to not touch this in the hangar, or when anyone is near the prop! Shocked
Learn something new about this airplane practically every week...
443LM Nanchang CJA
PostPosted: Tue Jan 22, 2019 4:32 am    Post subject: Start valve air leak Reply with quote
If you have to use the manual air start release, it requires two people
to start the airplane.  One to press the tab to open the air start valve
and the other in the cockpit to start the airplane.  The person on the
ground is essentially performing the function of the battery when the
start button is pressed.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
666CJA
PostPosted: Tue Jan 22, 2019 4:39 am    Post subject: Start valve air leak Reply with quote
Jon,
Are you saying you can start the airplane/CJ by yourself?
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Jon
> 666CJA
stephen.hayne
PostPosted: Tue Jan 22, 2019 6:25 am    Post subject: Re: Start valve air leak Reply with quote
Thinking about it, if it is like hand-propping... mixture, throttle, prop, air, brakes, prime, switches, mags, and then get out and press the tab?
So, perhaps I should have written "don't touch in the hangar" in green font. Except that I think I have left the air on, once maybe.
443LM Nanchang CJA
PostPosted: Tue Jan 22, 2019 10:03 am    Post subject: Start valve air leak Reply with quote
Possible. But not recommended. 😉
On Jan 22, 2019, at 6:45 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
Jon,
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Jon
>> 666CJA
Goto page 1, 2  Next
Page 1 of 2
