Europa-List: XS Port wing stiffener misalignment
duanefamly(at)aol.com
PostPosted: Fri Jan 25, 2019 9:18 pm    Post subject: Europa-List: XS Port wing stiffener misalignment Reply with quote
Are you aware of Service Bulletin 8? I believe it addresses this issue.
Sent from Windows Mail
Sent: â€ŽFriday‎, ‎January‎ ‎25‎, ‎2019 ‎6‎:‎59‎ ‎PM
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
I have just commenced build work on my XS wings, and have found that the
spanwise stiffener on the underside of the Port wing closure panel does
not line up with the rebates in the ribs, causing the skin to sit too
high and preventing a bond to the ribs, see spanwise photo. What have
others done who have been through this issue?
Many thanks,
Brian Phillips
Builder 489
sb_8.pdf
Download
 Filename:  sb_8.pdf
 Filesize:  101.05 KB
 Downloaded:  417 Time(s)
