GS tailwheel rudder drive mod question.
peterz(at)zutrasoft.com
PostPosted: Mon Jan 28, 2019 12:37 pm    Post subject: GS tailwheel rudder drive mod question. Reply with quote
I was wondering if someone could confirm that the rudder’s drive bracket is positioned 47” from the top of the rudder to the center of the rod (i am not cutting the bottom, so the instuctions dont really apply without doing math Wink
Many thanks,
Pete
A239
Kelvin Weston
PostPosted: Tue Jan 29, 2019 10:36 am    Post subject: Re: GS tailwheel rudder drive mod question. Reply with quote
Hi Pete
If you put a straight edge on the tip and measure along the inside of the leading edge (next to the hinges), my rudder measures 48 inches from the straight edge to the centre of the pushrod bracket.
Similarly, if you put the bottom of the rudder on the floor and measure up the inside of the leading edge from the floor to the centre of the bracket it is 6 inches.
However, the bracket position is determined by the lower hinge position on the rudder. If you have that in the right place as shown in Chapter 2 of the Build Manual, you should be ok.
Hope this helps.
Kelv Weston
Kit 497
kelv@kdweston.co.uk
