Noise cancelling headsets , do you wear them in a CJ or Yak?
motoadve
PostPosted: Fri Feb 22, 2019 7:29 am    Post subject: Noise cancelling headsets , do you wear them in a CJ or Yak? Reply with quote
I tried the Lightspeeds, Zulu 3 , and then the Bose A 20s.
If I turn on the ANR is too loud and noisy, I can barely hear anything above the noise, only way to be able to hear is with ANR turned off.
Anyone else experienced this?
www.Backcountry182.com
Cessna 182 P
CJ -6
CarterM
PostPosted: Fri Feb 22, 2019 7:57 am    Post subject: Re: Noise cancelling headsets , do you wear them in a CJ or Reply with quote
I use the A20s in my CJ. Never had a problem hearing, but they go through batteries like there is no tomorrow.
motoadve
PostPosted: Fri Feb 22, 2019 7:59 am    Post subject: Re: Noise cancelling headsets , do you wear them in a CJ or Reply with quote
Maybe my audio panel is the issue.
Cessna 182 P
CJ -6
Clouddog
PostPosted: Fri Feb 22, 2019 8:17 am    Post subject: Noise cancelling headsets , do you wear them in a CJ or Yak? Reply with quote
Myself,  I use Clarity Alofts. Been using them for 10 years. They are not noise cancelling but weigh 2 oz, foam ear buds that conform to your ear canals and don't need batteries. I put them on and put my helmet over them as the frame assembly fits behind your neck. Check them out if your going to Sun n fun or Oshkosh. They may even have a 30 day try for free but not sure. My wife loves her. Doesn't mess up her hair and no head clamp pain.
Greg "Clouddog" Wrobel
On Fri, Feb 22, 2019, 09:37 motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
--> Yak-List message posted by: "motoadve" <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)>
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=487737#487737
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
          -Matt Dralle, List Admin.
rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution
