XS Hi-Top conversion Mod 64/64B
Corinthian
PostPosted: Fri Mar 01, 2019 5:14 am    Post subject: XS Hi-Top conversion Mod 64/64B Reply with quote
Can someone please elaborate on the Hi-Top mod? Can the Mod 64B be installed without splitting the fuselage?
Nigel Graham
PostPosted: Sun Mar 03, 2019 1:27 am    Post subject: Re: XS Hi-Top conversion Mod 64/64B Reply with quote
The Hi Top mod is achieved by jacking up the front of the fuselage top moulding and inserting wedges of reinforcement either side prior to bonding the top in place. You can see this on the attached picture of one I did earlier.
From this you can see that it is only realistically possible to do this during the build. From the phrasing of you post, I’m assuming that your top fuselage has already been bonded to the “canoe” (bottom moulding) – in which case your options are limited.
Hope that helps
Nigel
(Club Mods Specialist)
 Filesize:  1.59 MB
 Viewed:  5450 Time(s)
Corinthian
PostPosted: Sun Mar 03, 2019 1:35 am    Post subject: Re: XS Hi-Top conversion Mod 64/64B Reply with quote
Thank you Nigel for your explanation.
