| charlesdavis(at)iuncapped Guest
				|  Posted: Mon Mar 11, 2019 9:20 pm    Post subject: Need help finding Hisonic Radio Filter Amperage  Rating. |   |
				| Hi Will
Try asking this on the "AeroElectric List", google should find it       for you, and I bet Bob will have the answer
 Charles
 On 2019/03/11 08:35 PM, Will wrote:
  	  | Quote: |  	  | Hello everyone!  This is my first post to this         list.  I'm adding a couple radios to my BD4 that I purchased         recently and have a question about a piece of equipment I found         under the panel.
 I’m             trying to find out the amperage throughput capacity of a             Hisonic radio frequency interference filter. I’m adding a             couple radios to my panel and based on their circuit breaker             requirement rating I’m guessing could add about 15 amps to             the avionics side of the buss bringing the total max load to             around 25A. The way the plane is currently wired all the             power for the avionics is fed through an old Hisonic RFI 40             Radio Frequency Interference Filter. I’m having trouble             finding much info on the filter. Looks like Cessna used             these at one point. My plane does also currently have an             alternator filter like this one.
 https://www.aircraftspruce.com/catalog/elpages/lsAlternatorfilter.php?recfer=16504 2
 Unfortunately,             I purchased the plane w/out being able to test fly it and as             such I’m not sure if there is extra alternator noise in the             plane or if this was just added for more assurance. What I’d             really like to know is how many amps this unit can handle             and if I should leave it in or take it out. I suppose that             it’s unlikely the filter will see 25A max draw ever as both             COM radios, one VOR nav, and a transponder would hall have             to be transmitting simultaneously to even get close to max             amp draw.
 I’m             just concerned that I could have a single failure point             lurking here. I have a feeling these aren’t used much any             more since I can’t find many available. Though             aircraftspruce does have a couple models for sale. https://www.aircraftspruce.com/catalog/elpages/lonestarFilter70amp.php?recfer=2351 1
 Are             you guys using these or is it more just old school gear that             isn’t used anymore?
 Will
 | |  |  | - The Matronics Avionics-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Avionics-List
