motoadve
Posted: Mon Mar 11, 2019 12:50 pm Post subject: Oil change |
Since I dont have an oil filter, I will be doing the oil change at 25 hrs.
Do I need to remove all the screens? or which ones are required to be inspected?
_________________ www.Backcountry182.com
Cessna 182 P
CJ -6 |
draftsjust417(at)gmail.co Guest
Posted: Tue Mar 12, 2019 6:18 am Post subject: Oil change |
As a safety measure, at every oil change I remove all my oil screens, rinse with avgas, blow dry with compressed air, visually inspect, reinstall and safety back into place.It's tedious but time well spent!
Justin
N280NC
On Tue, Mar 12, 2019 at 1:26 AM motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
Quote: | --> Yak-List message posted by: "motoadve" <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)>
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=488015#488015
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
cjpilot710(at)aol.com Guest
Posted: Tue Mar 12, 2019 7:19 am Post subject: Oil change |
A 10 micron oil filte will greatly extend the time between overhauls. I seen this not only my M-14p but on the B-24s PW1830 and B-17s W-1820s. I had over 1800 hours on my M-14 before I did a zero overhaul. I had done 2 top overhauls during that time. When we opened her up, she still looked clean in side. Most of the time I'd do oil changes at the 40 hours mark. On the B-17 & B-24 we change engines at around 1200 hours. On those engines not only fine oil filters but the way we ran them. During the war they were happy to get 400 hours on an engine. Jim "Pappy" Goolsby
hill(at)doctor-hill.com Guest
Posted: Tue Mar 12, 2019 8:35 am Post subject: Oil change |
Justin,
For years, I’ve been using the Cross 10 micron filter with the spin-on firewall mounted oil filter kit from Craig Payne.
www.hydrafil.com
Cross 1A9021
P/N RxC10DD67-S4-10CLB
Warren
N464TW
Mesa, AZ
[quote]On Mar 12, 2019, at 8:06 AM, "\"" <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> wrote:
A 10 micron oil filte will greatly extend the time between overhauls. I seen this not only my M-14p but on the B-24s PW1830 and B-17s W-1820s. I had over 1800 hours on my M-14 before I did a zero overhaul. I had done 2 top overhauls during that time. When we opened her up, she still looked clean in side. Most of the time I'd do oil changes at the 40 hours mark. On the B-17 & B-24 we change engines at around 1200 hours. On those engines not only fine oil filters but the way we ran them. During the war they were happy to get 400 hours on an engine. Jim "Pappy" Goolsby --
Posted: Tue Mar 12, 2019 10:42 am Post subject: Oil change |
Yes, have one in my 280NC as well & it works very well... well worth the
few extra $.
*Just* advised Jeremy to look into the same!
Thanks- Justin
On 12:40, Tue, Mar 12, 2019 Warren Hill <hill(at)doctor-hill.com wrote:
[quote] Justin,
www.hydrafil.com
Cross 1A9021
Warren
N464TW
Mesa, AZ
On Mar 12, 2019, at 8:06 AM, "\"" <cjpilot710(at)aol.com> <cjpilot710(at)aol.com>
Jim "Pappy" Goolsby
captPod
Posted: Tue Mar 12, 2019 12:53 pm Post subject: Oil change |
With respect to your latest post... You need to invest in a spin on oil filter AND a maintenance manual. The filter is probably the most cost effective improvement you can do to your engine. A manual will help you properly maintain your airplane and probably answer 90% of the questions you post.
Doug is a great asset to our community. Support him. He is always very helpful and I get parts usually in two days to Florida from him.
[quote] On Mar 12, 2019, at 12:08, Warren Hill <hill(at)doctor-hill.com> wrote:
Justin,
www.hydrafil.com
Cross 1A9021
Warren
N464TW
Mesa, AZ
> On Mar 12, 2019, at 8:06 AM, "\"" <cjpilot710(at)aol.com> <cjpilot710(at)aol.com> <cjpilot710(at)aol.com> wrote:
> Jim "Pappy" Goolsby
Posted: Tue Mar 12, 2019 1:14 pm Post subject: Oil change |
Justin, The common theroy is that any particulats in these engines over 25 microns in size cause engine wear. Therefore if you put a 10 micron filter to catch those larger particulats coming OUT of the engine, the whole system stays pretty clean. It is surprising too, how much dirty air these engine breath. Thus putting a airfilter on the carb intake is an excellent idea. The sand - and thats what most of it is, has more cutting power -if you will- then the carbon from combustion. Another choise is the oil you use. I use a detergent oil. This keeps sluge from building up in passage ways and restricting flow.
Jim "Pappy" Goolsby
wlannon(at)shaw.ca Guest
Posted: Tue Mar 12, 2019 8:34 pm Post subject: Oil change |
Pappy;
Actually you are using an AD or Ashless Dispersant oil which has a similar cleaning effect.
Automotive detergent oils can cause pre-ignition in air cooled engines which do not cool as uniformly as liquid. They are not approved for use in an aircraft engine.
Cheers;
Walt
Sent: Tuesday, March 12, 2019 2:12 PM
Subject: Re: Oil change
Jim "Pappy" Goolsby
-----Original Message-----
From: Michael Foster <michaelfoster(at)bellsouth.net>
To: yak-list <yak-list(at)matronics.com>
Sent: Tue, Mar 12, 2019 4:54 pm
Doug is a great asset to our community. Support him. He is always very helpful and I get parts usually in two days to Florida from him. Sent from my iPhone
On Mar 12, 2019, at 12:08, Warren Hill <hill(at)doctor-hill.com (hill(at)doctor-hill.com)> wrote:
Justin,
www.hydrafil.com
Cross 1A9021
Warren
N464TW
Mesa, AZ
Quote: | On Mar 12, 2019, at 8:06 AM, "\"" <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> wrote:
A 10 micron oil filte will greatly extend the time between overhauls. I seen this not only my M-14p but on the B-24s PW1830 and B-17s W-1820s. I had over 1800 hours on my M-14 before I did a zero overhaul. I had done 2 top overhauls during that time. When we opened her up, she still looked clean in side. Most of the time I'd do oil changes at the 40 hours mark. On the B-17 & B-24 we change engines at around 1200 hours. On those engines not only fine oil filters but the way we ran them. During the war they were happy to get 400 hours on an engine. Jim "Pappy" Goolsby -----Original Message-----From: Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)>To: yak-list <yak-list(at)matronics.com (yak-list(at)matronics.com)>Sent: Tue, Mar 12, 2019 10:19 amSubject: Re: Oil change As a safety measure, at every oil change I remove all my oil screens, rinse with avgas, blow dry with compressed air, visually inspect, reinstall and safety back into place. It's tedious but time well spent!
Justin
N280NC
Posted: Tue Mar 12, 2019 8:57 pm Post subject: Oil change |
Justin;
Speaking of safety measures using avgas (or any gasoline) as a cleaning agent is not a good idea. Actually it is a very bad idea! Invest in a 5 gal. pail of petroleum solvent for that purpose. Each oil company has it’s own name, the most common being “Varsol” from Imperial (now Exxon I think).
Walt
Sent: Tuesday, March 12, 2019 7:16 AM
Justin
N280NC
Cessna 182 P
CJ -6
FORUMS -
WIKI -
b Site -
Posted: Wed Mar 13, 2019 4:43 am Post subject: Oil change |
I typically use Stoddard solvent for general cleaning when a petroleum product is involved, tho the Chinese Maint Manual instructs to use avgas then air for cleaning the oil screens.Think Stoddard would be better?
Justin
On Wed, Mar 13, 2019 at 9:33 AM Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
Walt
Justin
N280NC
Virus-free. www.avast.com [url=#m_937950905597816385_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Posted: Wed Mar 13, 2019 9:46 am Post subject: Oil change |
Yes. I’m sure Stoddard is the same as Varsol. It will not evaporate and leave dirt on the part like gas and is much safer.
Of course it is a flammable fluid and should be treated as such, for example disconnecting the battery, removing trouble lights, etc. or any potential ignition source particularly when using a spray gun.
Stay safe.
Walt
Sent: Tuesday, March 12, 2019 9:11 PM
I typically use Stoddard solvent for general cleaning when a petroleum product is involved, tho the Chinese Maint Manual instructs to use avgas then air for cleaning the oil screens. Think Stoddard would be better?
Justin
Walt
Justin
N280NC
Posted: Wed Mar 13, 2019 1:43 pm Post subject: Oil change |
Walt, Right on.
I use AeroShell 100 plus. I quit using multi grade because I always seem to get oil leaks!.. We went to using single grade on the bombers too for the same reason. Plus its was cheaper.
Jim "Pappy" Goolsby
Viperdoc
Posted: Wed Mar 13, 2019 5:35 pm Post subject: Oil change |
Pull the main oil screen on the firewall, the capillary screen for the prop, and the sump/chip detector.
Doc
Sent from my iPad
_________________ Viperdoc |
glipaz
Posted: Thu Mar 14, 2019 6:46 am Post subject: Re: Oil change |
Pappy, is there any issue in changing from multi grade to the Aeroshell 100p plus? I thought I had read that changing from one to the other could cause flaking of particulates in the engine etc.
Gil
