Ram Air into Case Breather Assy
gardcycl
PostPosted: Sat Mar 23, 2019 1:16 pm    Post subject: Ram Air into Case Breather Assy Reply with quote
Why do Huosia engines have intruduced ram air into the breathing system?
what part does the Oil tank play having this additional air entering against a Yak system?
dsavarese0812(at)bellsout
PostPosted: Sun Mar 24, 2019 4:06 am    Post subject: Ram Air into Case Breather Assy Reply with quote
Ram air? Where do you believe the “ram air” duct is?
Dennis
http://forums.matronics.com/viewtopic.php?p=488210#488210
PostPosted: Sun Mar 24, 2019 4:21 am    Post subject: Ram Air into Case Breather Assy Reply with quote
Ohhhh! NOW I understand what you mean.
The Huosai/CJ does not have an inverted oil system. Therefore the open vent on the nose case. On the M14/Yak 52, it does have an inverted oil system and therefore the nose case vent is routed back to the oil tank. Hope that helps.
Dennis
n13472(at)aol.com
PostPosted: Sun Mar 24, 2019 6:38 am    Post subject: Ram Air into Case Breather Assy Reply with quote
The Housai has a ram air inlet between cylinders 9 and one this leads to the
rear blower gear box area. It
also has a wye connection to the oil tank vent. I do not thinks this put any
appreciable press in the engine
case as the front vent on the propeller gear box is open facing to the rear
thus dumping the air out.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM
gardcycl
PostPosted: Sun Mar 24, 2019 1:47 pm    Post subject: Re: Ram Air into Case Breather Assy Reply with quote
Comments Greatly appreciated Dennis, Tom and Carl, being a non standard oil tank, i will try and find a drwg for the tank fitted to this homebuilt
