Fwd: Covering ailerons
Viperdoc
PostPosted: Sat Mar 23, 2019 4:15 am    Post subject: Fwd: Covering ailerons Reply with quote
Sent a different way after being rejected.Doc
Begin forwarded message:
From: "Roger Kemp M.D." <viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)>
Date: March 22, 2019 at 11:22:20 PM CDT
Subject: Covering ailerons
What type foam is used for damming and adding form to the push rod attachment points on the aileron. The foam is high density. It does not dissolve when exposed to organics specifically MEK (methylethyl ketone).
[img]cid:0E244017-79F1-4E87-828A-40BD3E0DC16F[/img]
[img]cid:FAB74D12-191A-471D-AD90-DED7D9DC1ECC[/img]
[img]cid:E123C7DD-23AB-449D-917C-F60489FB1798[/img]
 Filesize:  315.3 KB
 Viewed:  2128 Time(s)
 Filesize:  347.16 KB
 Filesize:  322.68 KB
Viperdoc
