		bcone1381
  Joined: 25 Apr 2017 Posts: 42 Location: Southeast Michigan
				 Posted: Mon Apr 01, 2019 3:07 pm    Post subject: Magnetometer wiring |
				I will placing a magnetometer, LED Navigation lights, and LED Strobe Lights in my wings. Is it common and necessary to separate the Magnetometer wire bundle from all other wiring or can all of these be run together in one bundle?
  _________________ Brooks Cone
Bearhawk Patrol Kit Build |
		art(at)zemon.name Guest
				 Posted: Mon Apr 01, 2019 3:52 pm    Post subject: Magnetometer wiring |
				Brooks,
 I don't know the specifics of what you are doing but here are a couple of thoughts which might guide you:
 - Follow the manufacturers' recommendations for wiring.
 - Magnetometers need to be installed away from anything which has a magnetic field (steel and iron and magnets in things like servo motors). Their wiring is not particularly sensitive.
 - The wiring for strobes, even LED strobes, may require shielding. Follow the manufacturers' recommendations. (Did I say that already? 😎)
  In my Bede BD-4C, I put the magnetometer in the fuselage, far away from everything. The strobes are in the wingtips. There are no lights near the magnetometer.
     -- Art Z.
 On Mon, Apr 1, 2019 at 6:22 PM bcone1381 <bcone1964(at)gmail.com (bcone1964(at)gmail.com)> wrote:
  	  | Quote: | 	 		  --> AeroElectric-List message posted by: "bcone1381" <bcone1964(at)gmail.com (bcone1964(at)gmail.com)>
  Brooks Cone
 https://CheerfulCurmudgeon.com/"Love wins. Love always wins." Morrie Schwartz
		rick(at)beebe.org Guest
				 Posted: Tue Apr 02, 2019 4:56 am    Post subject: Magnetometer wiring |
				I don't know about         "common" but I would test it before you get things bundled up         too tightly. Closely follow the manufacturer's recommendations         on shielding and if they have diagnostics, use them. I had a lot         of trouble with my LED strobes interfering with the magnetometer         even though my magnetometer is in the tail. My plane was built         with standard Whelen strobes and I replaced those with Aveo LED.         I imagined LEDs would be electrically quieter but they're not.         When I installed the magnetometer I ended up having to replace         all the strobe wire and being very careful to make sure         everything was securely grounded as the manufacturers said to.         The magnetometer still registers every pulse but it's within         allowable tolerances now.
 --Rick
           On 4/1/2019 7:07 PM, bcone1381 wrote:
       	  | Quote: | 	 		          	  | Quote: | 	 		  --> AeroElectric-List message posted by: "bcone1381" <bcone1964(at)gmail.com> (bcone1964(at)gmail.com)
