Eddie
Posted: Sat Apr 06, 2019 11:14 pm Post subject: Weight of new XS cowling |
Hello All,
I recently ordered a firewall forward kit from Europa which came with a nice new cowling.
The weight of the cowl seems excessive though.
The top cowl is approximately 10 lbs and the bottom cowl is 14 lbs.
They are very thick in places (about 4.2mm where the prop hub opening will be once cut out).
Could some of you please let me know what yours weighed in at?
Eddie
_________________ G-SELF classic with XS cockpit module.
Was J3300 powered soon to be 912ULS powered |
JohnFrance
Joined: 17 Sep 2014 Posts: 84 Location: Grenoble France
Posted: Sun Apr 07, 2019 11:03 pm Post subject: Re: Weight of new XS cowling |
Hi Eddie,
You’re absolutely right about the increased weight of the cowlings. I purchased a lower Cowling about two years ago, when ready to install it was 1.6 kg heavier than the original one.
As you mentioned they are considerably thicker than the older model and hence the extra weight.
As an exercise in composite work I am repairing my original cowling and adding a cowl flap and the ULS cooling inlet.
John
_________________ Europa mono Nr 192 |
Eddie
Posted: Mon Apr 08, 2019 9:23 am Post subject: Re: Weight of new XS cowling |
Thanks for your reply John.
I think I need to discuss this with Europa then.
All the best
Eddie
