johnwigney(at)windstream. Guest
Posted: Fri Apr 12, 2019 7:29 am Post subject: Re : Elevator trim cutout switch |
Hi Kingsley,
I am not an instrumentation expert, but my conclusion is that the switch on my panel is a "DPDT ON/OFF/ON (MOMENTARY) 6 PIN TOGGLE SWITCH". If you poke around on the web, I think you can find one. An example is at
https://www.amazon.com/Etopars-Momentary-Miniature-Toggle-Dashboard/dp/B077P3868T/ref=sr_1_20?keywords=on+off+on+momentary+dpdt+toggle+switch&qid=1555082392&s=automotive&sr=1-20
Cheers, John
Subject: Re: Elevator trim cutout switch
From: Kingsley Hurst <kingsnjan(at)westnet.com.au> (kingsnjan(at)westnet.com.au)
Thank you for sharing this one John, an excellent solution IMHO.
Please don't go to any trouble but if you happen to know the Part No of
the switch I would be interested to know thanks.
Kingsley
On 12.04.19 5:32 am, John Wigney wrote:
| Quote: | I have watched the thread regarding runaway elevator trim with
interest. My panel was built by Aerotronics in Billings, Montana
(http://www.aerotronics.com/) and I have flown for over 1,000 hours
without any trim issues. However, the photo and sketch diagram below
show a trim cutout switch which Aerotronics included in my panel and
this may be of interest to Europa owners. The switch is 3 position :-
* Up = NORMAL
* Center = OFF
* Down (momentary spring loaded) = EMERGENCY REVERSE
kingsnjan(at)westnet.com. Guest
Posted: Mon Apr 15, 2019 8:06 pm Post subject: Re : Elevator trim cutout switch |
John,
Thank you for the info below and my apologies for not responding earlier.
I will try to source one over here as the postage from the 'States' is
over the top nowadays. It was once very reasonable and quick but alas,
those days have gone!
Best
Kingsley
