One sender 2 indicators
argoldman(at)aol.com
PostPosted: Mon Apr 22, 2019 7:25 pm    Post subject: One sender 2 indicators Reply with quote
Gents and ladies. Can one capacitive fuel level sender ( 0 to 5v) be connected to 2 electronic indicators ???
Rich
PostPosted: Mon Apr 22, 2019 7:37 pm    Post subject: One sender 2 indicators Reply with quote
At 10:24 PM 4/22/2019, you wrote:
--> AeroElectric-List message posted by: A R Goldman <argoldman(at)aol.com>
Absolutely . . . but it may take some
'system integration'. What kind of
'indicators' come with the system?
PostPosted: Tue Apr 23, 2019 1:58 am    Post subject: One sender 2 indicators Reply with quote
Thanks bob,
Indicator 1---Dynon Skyviwew requires 0-5V
Indicator 2 Real World Solutions EM-3 (rotary) requires 0-5V
The senders are 0-5V , Prinsten
Rich
In a message dated 4/22/2019 10:37:52 PM Central Standard Time, nuckolls.bob(at)aeroelectric.com writes:
PostPosted: Fri Apr 26, 2019 5:41 am    Post subject: One sender 2 indicators Reply with quote
Modern instrumentation generally present a very
small load on the sensor driving it. I.e. has
a high input impedance.
You can probably parallel the two displays
with no difficulty. Power the sensor from
ONE source only. Tie grounds for the indicators
and sensor to your avionics ground feature.
Parallel only the 0-5v signal to the pair of
displays.
At 04:56 AM 4/23/2019, you wrote:
Thanks bob,
Rich
PostPosted: Fri Apr 26, 2019 8:00 am    Post subject: One sender 2 indicators Reply with quote
Thanks bob. That’s good news
Rich
On Apr 26, 2019, at 8:40 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
displays.
Thanks bob,
Rich
In a message dated 4/22/2019 10:37:52 PM Central Standard Time, nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com) writes:
--> AeroElectric-List message posted by: A R Goldman <argoldman(at)aol.com (argoldman(at)aol.com)>
Bob . . . =================================== st">http://www.matronics.com/Navigator?AeroElectric-List =================================== cs.com =================================== om =================================== matronics.com/contribution ===================================
