FOT Hardware
phapp(at)yhpb.com
PostPosted: Tue Apr 23, 2019 3:54 am    Post subject: FOT Hardware Reply with quote
Hi,
I have B&C's FOT on my RV-8 firewall. It comes with brass hardware.
However I need a longer bolt for the thickness of the connectors for the standard battery and engine grounds. In AC 43.13-1B (11-76  11-79) I see  very specific material types called out for bonding connection hardware.
Question is,  do I need to stick with brass or can I go with the standard cadmium plated AN hardware we use everywhere else in our homebuilts?  If Bob suggests brass, what's a good supplier?
Kellym
PostPosted: Tue Apr 23, 2019 4:15 am    Post subject: FOT Hardware Reply with quote
With large current connectors, such as battery ground and engine ground
you do NOT need to connect to the FOT. Connect to any bolt going through
the firewall and you will be fine. The FOT grounds are for avionics that
are low current, prone to ground loops etc. Your high current
connections are fine using the metal airframe for ground. AN hardware is
also fine for those connections. If you try to stack those large
connectors all together with the bolt going through your FOT you are
asking for something not connecting well. On my RV-10 Vans has the
engine ground using the engine mount firewall bolts as the engine ground
connection. Maybe not ideal, but it works.
On 4/23/2019 4:52 AM, Paul Happ wrote:
Hi,
hardware.
Kelly McMullen
KCHD
ceengland7(at)gmail.com
PostPosted: Tue Apr 23, 2019 4:43 am    Post subject: FOT Hardware Reply with quote
What diameter are the B&C bolts? I made my own FOT using a brass blank switchplate & tabs from an electronic supplier, and for the bolt, I used a 5/16" brass bolt soldered to the plate. The bolts are available in pairs, complete with brass nuts, from your local hardware store or big box store. You just need to look in an unconventional area to find them. Smile
https://www.google.com/search?q=toilet+hold+down+bolts&oq=toilet+hold+down+bolts&aqs=chrome.0.0l6.8822j0j7&sourceid=chrome&ie=UTF-8
Virus-free. www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
On Tue, Apr 23, 2019 at 6:58 AM Paul Happ <phapp(at)yhpb.com (phapp(at)yhpb.com)> wrote:
Hi,
kenryan
PostPosted: Tue Apr 23, 2019 7:34 am    Post subject: FOT Hardware Reply with quote
Please remind me, what is FOT?
On Tue, Apr 23, 2019, 04:20 Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
> Hi,
> hardware.
art(at)zemon.name
PostPosted: Tue Apr 23, 2019 8:50 am    Post subject: FOT Hardware Reply with quote
forest of tabs
On Tue, Apr 23, 2019 at 10:51 AM Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
https://CheerfulCurmudgeon.com/"Love wins. Love always wins." Morrie Schwartz
bobnoffs
PostPosted: Tue Apr 23, 2019 1:54 pm    Post subject: FOT Hardware Reply with quote
forest of tabs
On Tue, Apr 23, 2019 at 11:54 AM Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
forest of tabs
