budyerly(at)msn.com Guest
Posted: Mon May 06, 2019 7:25 am Post subject: Jabiru Throttle Lever |
The push pull Vernier is fine for the Jab or one can install a two or three lever box from Aircraft Spruce. You will need a non-reversing throttle arm as the Bing carb uses a forward push to open and pull to close. I’ve used it and find it workable and allows me to hook the choke, or make a throttle friction, or carb heat as you see fit. Of course, some figuring is expected. Getting one of these to fit in the tunnel was not a big deal. It just fit between the sides of the XS cockpit module. Also has a friction knob if you like.
Two Lever Quadrant w/Friction
05-15925-F
$79.95
The ACS Vernier knobs are great also. Stay away from the cheap push button model which only moves when the button is pushed. Not for a throttle control. You want the throttle to be smooth and simple.
Comes down to what you want, multiple knobs or multiple levers. Each has advantages and disadvantages.
Best Regards,
Bud Yerly
Sent from Mail for Windows 10
tonyvaccarella
Posted: Mon May 06, 2019 12:58 pm Post subject: Re: Jabiru Throttle Lever |
Greetings all,
Thanks to those who replied to my post. I have decided to stick with the original design and go for the throttle lever arrangement. Im still having trouble however visualising this throttle lever housing and how its constructed. Does anyone have a picture of it that they can share with me? Seeing one would greatly help.
Many thanks.
Tony Vaccarella
Sydney
Australia
_________________ Tony Vaccarella
Mascot NSW 2020
Sydney Australia |
