uAvionix skyBeacon/skySensor wiring
ed.kettler
PostPosted: Fri May 17, 2019 6:06 pm    Post subject: uAvionix skyBeacon/skySensor wiring Reply with quote
Has anyone run the separate wire for the strobes for the uAvionix wingtip setup?
I have the wingtip off, and see there is a tube for a single wingtip light wire (power only, airframe ground). I suppose the next step is to remove the wing join fairings, then splice the new wires to the old and pull them through. Don't know about any connectors or other bits, so any advice and pictures would be greatly appreciated
Many thanks!
Ed
Ed Kettler
N53HM
