CJ Nose gear pressure
AlaskaChang801
PostPosted: Tue May 21, 2019 7:45 am    Post subject: CJ Nose gear pressure Reply with quote
After watching many videos of my plane taxiing around, I noticed that the nose gear never seems to dampen when going over bumps etc. the tire gives and that seems to be the only shock absorbing I’m getting from the nose gear. So in reality how much is the nose gear supposed to give and dampen and is it possible the nose gear pressure is too high and how do I adjust it if it is.
wlannon(at)shaw.ca
PostPosted: Tue May 21, 2019 9:59 am    Post subject: CJ Nose gear pressure Reply with quote
290 +/- 5 psi.
Nitrogen only. Special tool required unless previously modified.
Best advice: Contact you’re A&P.
