Exhaust manifold donut
Saber369(at)comcast.net
PostPosted: Sun Jun 02, 2019 7:03 am    Post subject: Exhaust manifold donut Reply with quote
Doing the annual on the CJ and found one of the exhaust manifold "donut" gasket needing replacement. I used an automotive asbestos gasket years ago to replace one but don't remember the part number. Any suggestions?
Sent from Xfinity Connect Application
richard.goode(at)russiana
PostPosted: Sun Jun 02, 2019 9:45 am    Post subject: Exhaust manifold donut Reply with quote
I am no expert on the Nanchang, but the seal between exhaust pipe and
cylinder head can be a problem area with the Russian M 14 engine. We
actually call them "olives", but I'm surprised that an automotive gasket is
thick enough the standard size for the M 14 "olive" is actually 10 mm
thickness, and we produce oversize ones according to a customer's
requirement, and these have been up to 15 mm!
Richard
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
GeorgeCoy
PostPosted: Sun Jun 02, 2019 12:13 pm    Post subject: Exhaust manifold donut Reply with quote
I believe Doug Sapp has them in stock. If not, then we have them in stock.
p/n 14-04-542.
George Coy
MotorstarNA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com
http://motorstarna.com/
SKYPE george.coy
wlannon(at)shaw.ca
PostPosted: Sun Jun 02, 2019 6:32 pm    Post subject: Exhaust manifold donut Reply with quote
For general information - these items are identical for the M14P, Huosai and
AI14R engines. The attaching nut is larger for the M14P cylinder but the
sealing
area is the same.
Walt
PostPosted: Mon Jun 03, 2019 12:08 am    Post subject: Exhaust manifold donut Reply with quote
Yes I was simply interested in the dimensions in that a satisfactory seal
seems to have been made with an automotive exhaust gasket, and if that is
the normal "asbestos" with a thin copper sheet on each side, I suspect it is
probably only around 4 mm thick, whereas the standard exhaust "olives" that
we make for the M 14 engine are 10 mm thick, and for customers where the
cylinder head has become worn (through running the engine with the exhaust
nut loose), we sometimes make special order "olives" up to 15 mm thick!
wlannon(at)shaw.ca
PostPosted: Mon Jun 03, 2019 8:58 am    Post subject: Exhaust manifold donut Reply with quote
Richard;
When you say 10 mm thick one envisions a solid piece of material. Though
I'm sure you are referring to the overall width which is approx. 10 mm it
could be confusing to those unfamiliar with these engines.
The only exhaust gaskets I have seen for these engines are formed from
steel, probably beginning in tubular form with a thickness of approx. 1 mm
(.04").
The sealing effect is obtained from the spring like resistance to further
deformation under tightening pressure of the nut.
Walt
PostPosted: Tue Jun 04, 2019 12:19 am    Post subject: Exhaust manifold donut Reply with quote
No, these are absolutely solid, made out of a soft mild steel. The standard dimension is 10 mm thickness, but some operators/pilots allow the exhaust nut to become loose, so then the flanged end of the exhaust pipe begins to "fret" against the cylinder head, eroding the metal. In these cases, according to the requirement of people, we make bigger "olives" which have been up to 15 mm thickness.
