Minimum separation between power cables and coaxial cable
PostPosted: Thu Jun 13, 2019 6:42 am    Post subject: Minimum separation between power cables and coaxial cable Reply with quote
At 11:03 PM 6/12/2019, you wrote:
--> AeroElectric-List message posted by: "Argonaut36" <fmlibrino(at)msn.com>
Could I bundle the coaxial cable for my radio (or transponder) antenna with a power wire that carries 5 Amps or there is a minimum separation requirement?
There is no reason for separating
such wires in the airplane. There
are NO system interconnect wires that
will swap significant noises amongst
themselves.
Argonaut36
PostPosted: Thu Jun 13, 2019 12:39 pm    Post subject: Re: Minimum separation between power cables and coaxial ca Reply with quote
Noted. Thanks!
