Intermittent Gear Up Light - CJ
ed.kettler
PostPosted: Fri Jul 05, 2019 1:04 pm    Post subject: Intermittent Gear Up Light - CJ Reply with quote
I am getting an intermittent Gear Up light failure on my right gear. Initially on retract, I get a solid red, then it blinks for a few cycles, then goes out. Bulb test shows all lights working, and I get the indication in both cockpits
Is this a latching problem with the gear up lock? Switch fault?
I will have it up on jacks this weekend, so anybody have any advice on what to check?
Ed
Ed Kettler
N53HM
dsavarese0812(at)bellsout
PostPosted: Sat Jul 06, 2019 6:27 am    Post subject: Intermittent Gear Up Light - CJ Reply with quote
Check the engagement "button/arm" adjustment that depresses the
microswitch.?? Using a flat blade screwdriver with someone in the
cockpit, depress the microswitch button and see if the light is
flickering when you first engage the microswitch manually.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
Ed
Ed Kettler
N53HM
http://forums.matronics.com/viewtopic.php?p=490070#490070
pennington.construction.i
PostPosted: Sat Jul 06, 2019 7:15 am    Post subject: Intermittent Gear Up Light - CJ Reply with quote
Ed
I agree with Dennis in testing the switch.
One question.   When you put your gear up.  Do you leave the gear handle in the up position.  Or do you put it in the neutral position?
Mark
N621CJ
On Sat, Jul 6, 2019 at 10:32 AM A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> --> Yak-List message posted by: "ed.kettler" <ed.kettler(at)gmail.com (ed.kettler(at)gmail.com)>
> Thanks
> Ed
> Ed Kettler
> N53HM
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
PostPosted: Sat Jul 06, 2019 7:19 am    Post subject: Intermittent Gear Up Light - CJ Reply with quote
Ed
Dennis made a good suggestion.
One question
When you put the gear up. Do you leave the gear handle up or put in the neutral position. ?
Mark
N621CJ
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Thanks
> Ed
> Ed Kettler
> N53HM
WIKI -
ed.kettler
PostPosted: Sun Jul 07, 2019 5:39 pm    Post subject: Re: Intermittent Gear Up Light - CJ Reply with quote
Thanks for the great tips.
Jon Boede and I worked on the plane yesterday, and we may have found the problem. The switch is held to the mounting bracket by two bolts, and the bracket is held to the plane by four bolts.
One of the two switch bolts was missing, so that was fixed. Jon also adjusted the switch end point. We will check it out during gear swings next week.
To answer Dennis' question, I leave the gear handle in the Up position the entire flight until preparing for landing.
Thanks again!
Ed
Ed Kettler
N53HM
