		jay-dub
				 Posted: Tue Aug 06, 2019 8:07 am    Post subject: Are front and rear gear selectors interchangeable? (CJ6) |
				As per the title, please. Can they be swapped? Our front one has failed and we removed and blanked the rear a couple of years ago.
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ CJ owner |
		byronmfox(at)gmail.com Guest
				 Posted: Tue Aug 06, 2019 8:23 am    Post subject: Are front and rear gear selectors interchangeable? (CJ6) |
				Sorry, the gear selectors cannot be swapped. Give Doug Sapp a call, and he’ll provide you with a replacement for the front gear valve.
 Blitz Fox415-307-2405
 On Aug 6, 2019, at 9:07 AM, jay-dub <flyjnw(at)gmail.com (flyjnw(at)gmail.com)> wrote:
		jay-dub
				 Posted: Tue Aug 06, 2019 8:26 am    Post subject: Re: Are front and rear gear selectors interchangeable? (CJ6) |
				Thanks, I thought that was the case. We have one available on our field as we need it in a hurry so we'll stick that on and get the other refurbed.
				 Posted: Tue Aug 06, 2019 8:36 am    Post subject: Are front and rear gear selectors interchangeable? (CJ6) |
				No. The rear is significantly different. The front and the two flap selectors are identical.
 Dennis
  	  | Quote: | 	 		   On Aug 6, 2019, at 12:26 PM, jay-dub <flyjnw(at)gmail.com> wrote:
  CJ and Yak-52 owner
  http://forums.matronics.com/viewtopic.php?p=490720#490720
		jay-dub
				 Posted: Tue Aug 06, 2019 8:41 am    Post subject: Re: Are front and rear gear selectors interchangeable? (CJ6) |
				Thanks, Dennis. Have I misunderstood or are you saying the rear flap selector is the same as the front gear selector?
				 Posted: Tue Aug 06, 2019 8:47 am    Post subject: Are front and rear gear selectors interchangeable? (CJ6) |
				In a CJ6A the QSF-2A (3 port valve) are used in the following positions:Front gear valve
 Front flap valve
 Rear flap valve
 12-5522-00 (5 port valve) is used:
 Only in the rear gear valve position
 The 5 port valve and the 3 port valves are interchangeable with those used in the Yak 52.
 Hope this helps,
 Doug
 On Tue, Aug 6, 2019 at 9:34 AM jay-dub <flyjnw(at)gmail.com (flyjnw(at)gmail.com)> wrote:
  	  | Quote: | 	 		  --> Yak-List message posted by: "jay-dub" <flyjnw(at)gmail.com (flyjnw(at)gmail.com)>
  CJ and Yak-52 owner
		jay-dub
				 Posted: Tue Aug 06, 2019 8:50 am    Post subject: Re: Are front and rear gear selectors interchangeable? (CJ6) |
				Certainly does. Many thanks.
				 Posted: Tue Aug 06, 2019 9:08 am    Post subject: Are front and rear gear selectors interchangeable? (CJ6) |
				Byron is correct, they are not interchangeable.We highly recommend that anyone changing their QSF-2A or the 12-5522-00 (3 or 5 port valve) add the new "Final Filter" when installing the new valve.
 There are basically only two things which kill these valves-- water and grit.  This is NOT a desiccant filter so it will not stop moisture, you should already have a desiccant filter installed to do that job.
 This new stainless steel filter is attached directly to the valve body in the air IN port, and will stop 100% of any junk (rust or grit) from getting into the new valve.  As many of you have noticed, the price of these valves has risen considerably in the past year and if you pay attention to the daily news about Trump and his trade war it should give us all the encouragement we need  to be a bit proactive in extending the useful life of these valves.  Keeping the air DRY and CLEAN is the very important, that being done will assure that these valves will last for many years.
 Best,
 Doug
 On Tue, Aug 6, 2019 at 9:29 AM Byron Fox <byronmfox(at)gmail.com (byronmfox(at)gmail.com)> wrote:
  	  | Quote: | 	 		  Sorry, the gear selectors cannot be swapped. Give Doug Sapp a call, and he’ll provide you with a replacement for the front gear valve.
		jay-dub
				 Posted: Tue Aug 06, 2019 9:44 am    Post subject: Re: Are front and rear gear selectors interchangeable? (CJ6) |
				Doug,
 Are you able to supply the final filters separately?
				 Posted: Tue Aug 06, 2019 9:58 am    Post subject: Are front and rear gear selectors interchangeable? (CJ6) |
				Yes, of course, I did not mean to imply otherwise.
 Doug
 On Tue, Aug 6, 2019 at 10:52 AM jay-dub <flyjnw(at)gmail.com (flyjnw(at)gmail.com)> wrote:
  Doug,
  CJ and Yak-52 owner
  http://forums.matronics.com/viewtopic.php?p=490727#490727
		jay-dub
				 Posted: Tue Aug 06, 2019 10:05 am    Post subject: Re: Are front and rear gear selectors interchangeable? (CJ6) |
				No implication suggested. Will contact you off list.
