BNC connectors – Tool recommendation/Installation question
Argonaut36
PostPosted: Wed Aug 14, 2019 7:57 am    Post subject: BNC connectors – Tool recommendation/Installation question Reply with quote
I am interested in purchasing a wire stripper that can be used for cutting the dielectric in RG400 coax cable to expose the central conductor (I use a blade for the outer sheath and the outer shield). I understand that the central conductor is similar in diameter, but not identical to electrical cable size 16 and I would like a wire stripper that is adjustable so that it can be adjusted to work very precisely with RG 400 coax cable. Any recommendations?
I also have a question on installing BNC connectors on RG400 coax cable: the stripping lengths that I use are the following: outer shield: 3/8”, dielectric: 3/32”, central conductor: 9/32”. Are these distances correct? I can’t quite get the ferrule to touch the main body of the connector. I assume that no gap is acceptable.
John M Tipton
PostPosted: Fri Aug 23, 2019 1:06 am    Post subject: Re: BNC connectors – Tool recommendation/Installation ques Reply with quote
Check out these Ebay items:
eBay item number: 303261899740
eBay item number: 123868770273
Argonaut36
PostPosted: Fri Aug 23, 2019 8:31 am    Post subject: Re: BNC connectors – Reply with quote
Thanks, John.
I did a search on ebay (worldwide and no filter selected) for the item numbers listed in your post, but nothing came up. Could you please provide alternate methods to find these items on ebay or on other websites?
