Approved for spins?
peterz(at)zutrasoft.com
PostPosted: Fri Sep 27, 2019 8:38 am    Post subject: Approved for spins? Reply with quote
I realize the Europa has been tested for and has good spin recovery characteristics.
Some Europa's in the US have been placarded with "intentional spins prohibited". Is this an arbitrary restriction? Is there an official Europa Aircraft document which restricts spins or any other  'aerobatic' manuver (I realize snap rolls would be a bad idea)? I have not yet found anything on the co's website.
Here in Canada spins are to be demonstrated by the instructor as part of our PPL (we used to be tested on them too, but that has been removed from the syllabus), and one can obtain training in one's own homebuilt. So thus my question about spins.
Many thanks,
Pete
#A239 xs (still parts)
#120 classic (new owner)
Burrilla
PostPosted: Sat Sep 28, 2019 7:50 am    Post subject: Approved for spins? Reply with quote
For the Owners Manual page 5-14
Spinning
Intentional spinning is prohibited.
Enough said.
Alan
Many thanks,
Pete
PostPosted: Sat Sep 28, 2019 8:19 am    Post subject: Approved for spins? Reply with quote
Thx. Hmmmmm...i wonder why, since the design is so well spin proven and even proudly shouted from the treetops in the original europa promotion video?
Seems to be quite the waste.
Cheers and thx.
Spinning
Enough said.
Alan
> Many thanks,
> Pete
AirEupora
PostPosted: Sat Sep 28, 2019 9:35 am    Post subject: Re: Approved for spins? Reply with quote
Spinning
Both the proof-of-concept (P.O.C..) aircraft G-YURO and the kit prototype G-ELSA have been extensively spin tested, up to 12 turns, and found to have excellent spin recovery with standard spin recovery techniques. Both aircraft were also found to recover satisfactorily from fully developed spins by removing both hands and feet from the controls depending on trim setting.
However, due to builder differences, individual kit aircraft may not exhibit the same spin characteristics as our prototypes. The prototype aircraft have a developed spin rate (after 3 turns) of approximately 180° per second with a 60° nose down attitude.
If a spin is inadvertently entered;
• Close the throttle.
• Retract flaps if deployed
• Full rudder against direction of spin.
• Slight pause.
• Stick forward to neutral.
• Centralise rudder as spin stops.
• Recover from dive to a climbing attitude, applying power as the nose passes above the horizon.
PostPosted: Sat Sep 28, 2019 1:24 pm    Post subject: Approved for spins? Reply with quote
Cool thx, i did read that after i dug out the POH from the goodie pile that came with 120.
Cheers and thx,
Pete
Ps - in canada aerobatic maneuvers once demonstrated are legal...wise or not.
On Sep 28, 2019, at 1:35 PM, AirEupora <AirEupora(at)sbcglobal.net> wrote:
Spinning
• Slight pause.
http://forums.matronics.com/viewtopic.php?p=491502#491502
