duanefamly(at)aol.com Guest
Posted: Fri Oct 25, 2019 11:02 pm Post subject: Europa-List: AoA - Angle of Attack Indicator |
James,When I was building I purchased the AOA Sport System for Composite Wing from Aircraft Spruce. Their part #10-04792. But I had my wing open, it was easy to install this system. Since the detector sits out about two feet from the end of the wing, you would have to be able to feed two thin nylon tubes from the detector to the wing root, install a connector that can be split at the wing root when you have to remove the wing. It provides both visual and audio warnings. Once flying, the calibration required was easy and straight forward. There is another Europa at my airport that is flying this same system. I hope this helps.Mike Duane N377EAEuropa XS Conventional Gear
Las Vegas, Nevada
Sent from Windows Mail
Sent: ‎Friday‎, ‎October‎ ‎25‎, ‎2019 ‎2‎:‎30‎ ‎PM
--> Europa-List message posted by: "Mallard" <james(at)kingdom.ie>
Has anyone ever fitted an AoA Indicator to their Europa? If yes, what model did you fit and was there a reason why you selected that particular model?
Cheers
James
Seat of my pants
http://forums.matronics.com/viewtopic.php?p=491973#491973
_-============================================================
_-= - The Europa-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Europa-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
Mallard
Posted: Sat Oct 26, 2019 4:18 pm Post subject: Re: Europa-List: AoA - Angle of Attack Indicator |
Hi Mike,
I found your AoA system on Aircraft Spruce but they don't show the Vane part, only showing the cabin display. The cost is the cheapest I've seen but I was wondering if it (or any model) could be retro-fitted to an existing 1995 Classic.
Would you be able to post photos of your Vane installation? If it protrudes from the end of the wing, is it susceptible to damage?
Cheers
James
_________________ Seat of my pants |
