clivesutton
Posted: Tue Dec 03, 2019 6:49 am Post subject: Tank sender that matches Airworld Capacitive probe cutouts? |
Fellow Europa-ers,
I've got an Airworld Capacitive probe installed in my RH tank lobe - which connects (only) to its own analogue gauge and will not provide a second/separate variable voltage output for connection to e.g. FF-1 and/or EIS4000 fuel tank level readout instruments. The Airworld solution sort of works OK, but the gauge is highly non-linear - resulting in the contents being quite difficult to ascertain at capacities approaching 'full'.
Given that my tank has this cutout in its top surface, can anyone suggest alternative voltage-type probes that can replace it but still use the 5 fixing holes cut for the Airworld bendable probe - or at least be used without creating a fuel leak, please?
Any advice/experience most welcome
Clive Sutton
G-YETI
