Posted: Sat Jan 25, 2020 12:10 pm Post subject: Battery Voltage Under Load, no Charger |
At 12:56 PM 1/25/2020, you wrote:
Quote: | --> AeroElectric-List message posted by: "farmrjohn" <faithvineyard(at)yahoo.com>
The situation that prompted my question is when I switched the battery on it indicated 12.8 volts. After I turned on the equipment I was working with (lights and radios) I noticed the voltage holding steady at 12.3. Unfortunately I didn't check the amps at that time. After I was done, I switched everything off then started the engine normally and the voltage was up to 14.2 when I switched on the alternator, amps were 6+. |
Having no more details, it sounds like things are
fine.
Have you ever cap-checked this battery? What
kind, what size, how old?
farmrjohn
Posted: Sun Jan 26, 2020 8:11 pm Post subject: Re: Battery Voltage Under Load, no Charger |
fine.
Bob . . . |
It's a Concord RG25, installed 3-23-16. I haven't cap-checked it.
