| philperry9
				|  Posted: Fri Feb 28, 2020 8:09 am    Post subject: Fwd: Service Bulletin SB 19-09-09 Published - Inspect RV-10 |   |
				| I just saw where this was posted.   Has anyone here seen any of these issues yet?
 I know this area seems to have a lot of play and the bushings are pretty sloppy.   I had some custom bushings turned to minimize the slop, but it really didn’t make that much of a difference.    Perhaps the cracks are caused by an unrelated issue?
 Final question.   It sounds like Vans has redesigned the nose gear since many of us received our kits years ago.  Does anyone know what changes were made?
 Phil
  	  | Quote: |  	  |
 Service Bulletin SB 19-09-09 Published - Inspect RV-10 gear leg mount lug
  	  | Quote: |  	  | Van's Aircraft has published a new Service Bulletin for the RV-10, SB  	19-09-09. This bulletin directs RV-10 owners to inspect the inboard  	attachment lugs on the RV-10 nose gear leg for potential cracks at a  	specific location. If no cracks are found, the gear leg is serviceable and  	you may continue to fly the airplane and re-inspect each year at the annual  	condition inspection. Replacement is not necessary in that case.
 If a crack is found, owners are directed to order a kit that contains an  	updated RV-10 nose gear leg and associated hardware. This is described in  	the service bulletin document.  	 	continue
 | |  |  | - The Matronics RV10-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?RV10-List
