paul.zimmer00(at)gmail.co Guest
				 Posted: Tue Mar 03, 2020 2:53 pm    Post subject: Fwd: AeroElectric-List: This doesn't seem right, but what do |
				See follow up response.
 ---------- Forwarded message ---------
 From: Paul Zimmer <paul.zimmer00(at)gmail.com (paul.zimmer00(at)gmail.com)>
 Date: Mon, Mar 2, 2020 at 5:37 PM
 Subject: Fwd: AeroElectric-List: This doesn't seem right, but what do I know
 To:  <aerobatic-list(at)matronics.com (aerobatic-list(at)matronics.com)>
 Date: Mon, Mar 2, 2020 at 11:29 AM
 Subject: Re: AeroElectric-List: This doesn't seem right, but what do I know
 To: Bob Nuckolls <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)>
  Follow up.  During normal cruise (following  start and battery recharge after start), the  bus voltage varies from ~13.7 to ~14.0V. The current  flow to/from the battery varies both in and out up to a max of 9 amps  out all the while battery voltage remains steady at ~13.9V. During these  times of  battery discharge, load was  static (which is to say the load was not deliberately changed).   Any  insight as to what is going on is appreciated. I have a spreadsheet with  the data from this flight that was generated from my my EFIS, but which  I was unable to upload as an attachment to this email.
   	           		Virus-free. www.avast.com 		 	 [url=#m_5743073549242824905_m_3416343911643763062_m_650452575105309318_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
 On Tue, Jan 28, 2020 at 2:12 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
  	  | Quote: | 	 		                     If you were using a shunt, I'd suggest       checking any fuseholders used to protect the sense wires. Any       minor variations in resistance in the sense lines can cause       significant instrument error, showing discharge.
        Charlie
        On 1/28/2020 10:46 AM, Paul Zimmer wrote:
       	  | Quote: | 	 		                         I can’t say that I’ve noticed a bus voltage drop           during these times of battery outflow, but before I say one           way or the other, I’ll need to pay a little closer attention,           and perhaps record the engine monitor parameters during a           flight which would allow for an after the fact thorough           analysis of what actually went on.  I’ll circle back at a           later date.  Thanks
                     On Tue, Jan 28, 2020 at             10:43 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>             wrote:
             	  | Quote: | 	 		                                <snip>
                   	  | Quote: | 	 		  These periods of flow to/from                   the battery are short
                    in duration normally lasting only a few seconds.
                    Is this normal and to be expected, or does it
                    suggest a problem with the internally regulated
                    alternator, or perhaps with the current sensor itself?
                    Any insight explaining what I am seeing will be                   appreciated. |
                    The battery's physics reacts to BUS VOLTAGE.
                    Any period battery energy outflow MUST be
                    paired with a drop in bus voltage to something
                    below the battery's present open-circuit
                    voltage.
                    The voltage doesn't have to drop to
                    the battery's natural delivery
                    level (~12.5 volts for SVLA) . . .
                    a battery across an operating bus
                    will support small outflow currents
                    at voltages higher than 12.5.
                    What is your normal bus voltage and do
                    you notice any depression of voltage
                    that corresponds to battery outflow
                    events?
  |  | - The Matronics Aerobatic-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Aerobatic-List |
