RV10-List Digest: 1 Msgs - 03/05/20
dlm34077(at)gmail.com
PostPosted: Fri Mar 06, 2020 7:38 pm    Post subject: RV10-List Digest: 1 Msgs - 03/05/20 Reply with quote
I believe if you check with vans they will confirm that simply pulling the tail in first and using a tow bar for steering will work. Of course you will need a remote control for the winch.
On Fri, Mar 6, 2020 at 12:51 AM RV10-List Digest Server <rv10-list(at)matronics.com (rv10-list(at)matronics.com)> wrote:
Today's complete RV10-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the RV10-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2020-03-05&Archive=RV10
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2020-03-05&Archive=RV10
                           RV10-List Digest Archive
                     Total Messages Posted Thu 03/05/20: 1
Today's Message Index:
     1. 08:26 AM - Hangar winch  (Gordon Anderson)
________________________________  Message 1  _____________________________________
Time: 08:26:57 AM PST US
Subject: Hangar winch
From: Gordon Anderson <mregoan(at)hispeed.ch (mregoan(at)hispeed.ch)>
Dear all,
I have an option on a T-hangar which needs the plane to be moved uphill, tail first,
into a narrow space (8 inch clearance each side of the HS).  Doing this
alone by hand with a Bogi-Bar is likely to result in tail damage sooner rather
than later.
The hangar already has an electric winch installed, which is slow enough but has
a pretty brutal yank when starting.
Im thinking of attaching the winch cable with a bungee to the top of the nose gear
leg, and passing the cable through a karabiner in the tail tie-down to pull
the tail straight without exerting any axial force on it. I would still need
a dolly for the nose wheel or push the tail down to keep the nosewheel off the
ground whilst moving.  Those options seem complex / impractical.
Its nice to work the brain again so long after the build is complete, but if someone
has already got a great idea or experience Im happy to borrow!
Cheers to all from a rather rainy Switzerland.
Gordon
HB-YVJ 41015
WIKI -
