Builder's tool set wanted
lwalters2(at)bellsouth.ne
PostPosted: Tue May 05, 2020 7:49 am    Post subject: Builder's tool set wanted Reply with quote
This may be too late, but I'll be at the airport from 1:00 on.
Linn
On 5/4/2020 6:38 PM, bechis1(at)att.net (bechis1(at)att.net) wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Hi Linn, thinking about flying down there tomorrow, Tuesday, if you�re ok with it.� What time is good?
Thanks.
Bruce.
Bruce Chisholm
407-414-7646
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) <owner-rv-list-server(at)matronics.com> (owner-rv-list-server(at)matronics.com) On Behalf Of Linn
Sent: Wednesday, April 8, 2020 5:46 PM
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: Re: Builder's tool set wanted
c'mon down!� I'm in the hangar almost eve3ry weekday.� #65.
On 4/8/2020 11:51 AM, bechis1(at)att.net (bechis1(at)att.net) wrote:
Hi Linn � this is great info.� Once this virus thing is over I would love to visit and take a look at your plane and tools.� I have a 172 so I can fly into Valkaria anytime.
Thanks!
Bruce.
Bruce Chisholm
407-414-7646
Sent: Wednesday, April 8, 2020 8:30 AM
Hi Bruce!� I'm building a -10 at Valkaria Airport, X59. Should be getting my inspection when the virus quarantine is over.�
�I'm holding onto my tools since I may be a 3 time offender.
Do not buy cheap tools made for cutting as they dull quickly.
Buy a couple packs each of #30 and #40 drills.��� Plus tap and body drills for #6,8,10 ...... get a couple sets. plus the taps.� A couple sizes of deburring bits that fit a battery screwdriver is a must have.� Stock up on mutiple TPI blades for the bandsaw.� I have an 'automatic bandsaw', the type that has a vice to hold material as the arm cuts it off.� Saves a lot if hacksaw work on parts that won't go through the bandsaw.� The fiberglass parts are crap (IMHO) and I used an angle grinder on mine.� You might consider putting blue foam in the doors to stiffen them but you'll need stronger struts for the extra weight.� I didn't do it because I didn't think of it in time, but you might consider mounting the desser monster tires before making up the wheel pants.
These recommendations should deplete your bank account for starters!!!
Linn
On 4/8/2020 7:25 AM, bechis1(at)att.net (bechis1(at)att.net) wrote:
I am re-posting this message to hopefully a larger forum.� Sorry if� you already received it.
I am a first-time RV-10 builder and will be needing a complete tool set soon. �Will need all of the sheet metal tools in Vans� list plus a bandsaw and any other recommendations. �I was wondering if anyone desires to sell some or all of their set, I will entertain reasonable offers.��
Thank you!
Bruce Chisholm
Orlando, Florida
Virus-free. www.avg.com
