| docclv(at)windstream.net Guest
				|  Posted: Wed May 06, 2020 12:53 pm    Post subject: 15x6x6 tire and tube |   |
				| Guys:  Ran over some crushed rock taxiing (It looked like Obsidian or
Flint--Sharp) and blew a main tire.  Had to get a new tire and tube.
 The tubes sent from Vans have straight valve stems which are hard to get
 air in.
 Built 2nd RV10 with Matco Wheels and Brakes.  They have tubes with
 90-degree stems which are hard to get air in (I put 2.5 inch access
 plates in the wheel pant when built for airing the tires).  Went on line
 to look for a workable tube for both the Grove (Vans wheels) and Matco
 wheels.
 Aircraft Spruce has tubes from $29.35 for Aero Classic to $75.95 for
 Good Year.  Both are 90-degree stem bent tubes.  Wicks has Carlisle
 tubes for $33.06 with a 45-degree (TR 87) Part # 320290 bent stems (This
 works well).  However the same Carlisle 15x6x6 TR 87 Lawn, Garden &
 Trailer tubes at the local farm supply store is $9. 69. I change all my
 main gear tubes.  Easy to air now.
 Thought you could use this tip.
 | |  |  | - The Matronics RV10-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?RV10-List
