alterntive rotax regulator [was: Re: Re: Is there any reaso
rowlandcarson(at)gmail.co
PostPosted: Mon May 18, 2020 5:56 am    Post subject: alterntive rotax regulator [was: Re: Re: Is there any reaso Reply with quote
On 2020-05-16, at 13:02, Pete <peterz(at)zutrasoft.com> wrote:
I looked over the instructions, and looks quite straightforward......i think tho i’ll keep it in my back pocket as plan B in case an AVC1 purchase doesn't pan out (the overall effort due to its pcb and parts lead-times are detractors for me). The over-voltage feature of the AVC1 is also quite tempting Smile
I had a look over the instructions, and downloaded the additional linked documents, mainly as an academic exercise.
The show-stopper for me is that the PCB board design file is apparently created in EAGLE v3 and that cannot be opened by any version of Eagle currently found in the wild (tried v9.6.1 & 5.12.0, both run fine on my Mac but refuse to open the file). Looks like the board was designed on a machine still running DOS!
Does Jim Butcher have a way of opening the file, or is there any way of contacting the author to see if he can translate the file to anything more modern?
My efforts to find a solution through the AutoDesk EAGLE help forum have hit a brick wall.
in friendship
Rowland
cakeykev(at)gmail.com
PostPosted: Mon May 18, 2020 6:20 am    Post subject: alterntive rotax regulator [was: Re: Re: Is there any reaso Reply with quote
Schicke regulator is brilliant
Kevin Challis
G ODJG
in friendship
Rowland
rparigoris
PostPosted: Mon May 18, 2020 2:44 pm    Post subject: Re: alterntive rotax regulator [was: Re: Re: Is there any r Reply with quote
Hi Group
I purchased a AVC1 regulator from B and C for Rotax 914. It has adjustable voltage set-point and adjustable low voltage warning. It has a very nice heat sink that's coated with conductive Nickel Plating and has provisions for two grounds.
Here's information that was sent to me from them:
B&C now has a Ducati replacement regulator. It’s a plug and play replacement, has OV protection, warning light output with selectable LV setpoint, and adjustable charging voltage. The unit has been tested by Van’s Aircraft and needs no additional cooling. Purchase includes phosphor bronze connectors. Cheaper connectors can get loose and arc. This caused many of the ducati units to fail. B&C is running free shipping now too.
Relevant links:
Bandc.com/avc1install
bandc.com/wp-content/uploads/2020/04/QuickFacts_AVC1_2020.pdf
Nathan
Nathan Bainbridge
B&C Specialty Products, Inc.
123 East 4th Street
Newton, KS 67114
(316) 283-8000
bandc.com
Ron Parigoris
