RX-7 Alternator mod - negative spike diode needed?
PostPosted: Wed May 27, 2020 6:51 am    Post subject: RX-7 Alternator mod - negative spike diode needed? Reply with quote
After my OV crowbar blew up, I took a closer look and am now wondering if I should add a diode from ground to the EM-36 field winding terminal to curb any negative spike.
Wouldn't hurt . . .
Normally, without the mod, any negative spike resulting from powering the field winding would be absorbed by the three small diodes and rectifier diodes going to ground.
And perhaps I should also a diode in series with the wire from the breaker to the alternator field terminal so a positive spike from the field winding won't trigger the OV module?
No positive spikes . . . not necessary.
BTW, the alternator does have a built-in capacitor over the output (B+) not shown on the schematic, but visible to the right in the photo and from the outside of the alternator, but doesn't affect the voltage regulator.
Nice work!
