Z101 has been released under Rev A (Robert L. Nuckolls, III)
david(at)carter.net
PostPosted: Thu May 28, 2020 2:19 pm    Post subject: Z101 has been released under Rev A (Robert L. Nuckolls, III) Reply with quote
Quick question on this diagram:  Near the upper left, there is a feed coming off of the battery bus that is labeled for a 30A fused feed to "BOBUS". Is that correct? I see two feeds coming into to the brownout / CD bus: 1 from the diode bridge that feeds the engine bus, and one (switched) directly from the battery side of the battery contactor.
Thanks!
David Carter
david(at)carter.net (david(at)carter.net)
PostPosted: Thu May 28, 2020 3:14 pm    Post subject: Re: Z101 has been released under Rev A (Robert L. Nuckolls, Reply with quote
In the latest revision of Z101, the 30 amp fuse has been replaced with a
fusible link. Both the engine bus and the Brownout/Clearance Delivery bus
can get power from either the up stream or down stream side of the master
contactor. Your observations are correct.
Joe Gores
