Diodes - Ground Pwr/Battery Master Contactors
PostPosted: Sun Jun 28, 2020 5:24 am    Post subject: Diodes - Ground Pwr/Battery Master Contactors Reply with quote
At 08:04 AM 6/28/2020, you wrote:
Hi - � This is my first question for the forum. �
I am building RV8 w single aft battery/ dual alternator.� Ground power contactor and battery master battery contactors are aft. � Obtained both contactors from B&C with 1N5400 diodes.� Total of 3 diodes � (2 � on the Ground Pwr Contactor � and � 1 on the Battery Master Contactor.)
Diagram from Aircraft Spruce with the Piper jacks written by AeroElectric � showed using 1N5402 diodes on � the � Ground Pwr contactor.� Are there compelling reasons � to � swap out � my 1N5400 diodes with 1N5402 or other?
Thanks� for reading and for responding.
The 1N54xx series devices are essentially
identical for our purposes. The XX denotes
reverse voltage rating that range from 50
to 1000 volts. See:
https://www.vishay.com/docs/88516/1n5400.pdf
For our purposes, any of those devices
will be operated within limits on a
14v aircraft.
Drum
PostPosted: Wed Jul 01, 2020 12:47 pm    Post subject: Re: Diodes - Ground Pwr/Battery Master Contactors Reply with quote
Thank you!
Drum G
RV8 - Firewall Forward
Holly Hill, SC
