Let's not loose focus
PostPosted: Tue Jun 30, 2020 8:38 am    Post subject: Let's not loose focus Reply with quote
The only real shortcoming I have found is that it does not include a fuse component. It shows the current during simulation so you can size things, but it would be great to be able to install a fuse and test all combinations of devices to ensure that calculations for wire size and such have been done correctly.
Is this a simulation app? Calculations for wire size etc?
A word of caution. Take care spending a lot of time
wrestling with software installation and familiarization
that (1) doesn't add to meeting design goals and
(2) simply goes to confirmation of exceedingly rudimentary
decisions . . . wire sizes and fuses . . . really?
The PRIMARY concern is to craft a failure tolerant
system that has low parts count, minimized crew
controls that beg for proper decisions in flight
followed up by minimized weight and cost of ownership.
All those AC43-13 driven 'calculations' and admonitions
are like studying how to boil eggs . . .
There's a thread running now that claims
roots in Z101. ALL of the z-figures
were crafted with a particular airframe/mission
in mind. Occasionally I run a across a builder's
assertion that "I took Zxx and crafted a really
whippy electrical system." Then I find the
drawings only slightly resemble the the
referenced Z-figure due poorly reasoned
changes.
In some cases, the differences created
failure modes hazardous to people and other
living things.
The builder of this airplane attended my
seminar and bought the book . . . but
failed to join us here on the List before
crafting his own "whippy" electrical system:
https://tinyurl.com/msfmldj
There was no critical review of the electrical
system condition/architecture for this
accident . . . but I'd bet $100 that
root cause for this incident would have
been one of those "Gosh . . . I could have
had a V8" moments:
https://tinyurl.com/y7xksy6v
Finally, there's this sad story of a
horrifyingly dismissive attitude toward
the simple physics of flight, aviation
legacy processes/practices and just
common sense.
https://tinyurl.com/mwbk9qs
Root cause for ALL of these (an many
more) bad days in the cockpit was
stone simple.
Years ago, I used this tag on my email
signature:
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
This was in no way intended to be tongue-
in-cheek . . . it's serious . . . some
times deadly serious.
If I've put my foot in a tar bucket,
I'm the FIRST person that needs to know about
it. A teacher's worst nightmare is the
discovery of an ignorant or careless complicity
in the dissemination of poor if not hazardous
information.
If one wishes to exploit a z-figure,
then start with the drawing AS-PUBLISHED.
Study it for failure to meet personal design
goals. If changes are indicated . . . DISCUSS
THOSE GOALS RIGHT HERE on the List. If changes
are warranted or a new z-figure is useful
then by all means let's do it. But make sure
that design goals are (1) realistic
and (2) improve the failure mode effects analysis.
This List is more than a SOURCE FOR GOOD
info . . . it's a FILTER FOR BAD info.
To my way of thinking no single failure will
create an emergency situation. Further, your
plan-B checklist should have a minimum of crew
tasks for failure mitigation (like flip two
switches . . . and keep flying?) and no
requirement for in-flight analysis. Save those gray-
mater exercises for in the hangar.
Trust me . . . wire and fuse sizes are
wwwaaayy down the list of your building
concerns.
supik
PostPosted: Wed Jul 01, 2020 1:37 am    Post subject: Re: Let's not loose focus Reply with quote
changes.
living things.
I guess it's me. That's the reason I shared my schematics on this forum. I don't need to be an example for accident analysis post-mortem. I would appreciate your comments. I am especially interested in NO GO issues and failure analysis.
I understand a load analysis is required to determine proper fuse ratings+wire size -I'll attach the load analysis to my thread..
Where I think it will work, you might find a critical issue..
Igor
RV10 in progress
PostPosted: Wed Jul 01, 2020 7:21 am    Post subject: Let's not loose focus Reply with quote
Please don't take anything I wrote personally . . .
in fact, by bringing your ideas and questions to
the List, you do'n the right thing!
Keep in mind that there are a lot
of subscribers to this list who don't
actively participate. Nonetheless they
find value in watching what passes by.
I try to tailor my offerings for a CLASS
as opposed to individuals. We haven't had
a personality clash on the List since
GMCJetpilot days . . . and I'm hoping
that doesn't happen again.
I've not engaged in your project as
yet for a variety of reasons not the
least of which is time. At the same
time, I'm intently interested in how
the rest of the 'team' are rising
to your cause.
I am encouraged by what I'm reading.
At the same time, I'm protective of our
mission and process here. Whenever I
encounter a project wherein the builder
claims some foundation based on the
AeroElectric Connection, I have an
obligation to my readers and all who
participate here to make sure that the
mission and process are not being diluted
or modified without foundation in physics
and critical thought.
Keep up the good work guys!
P.S. Remember that fuses/breaker protect
wire. The constellation electro-whizzies
in our airplanes could not care less what size
wire supplies energy as long as it
is adequate and reliable. Had a reader
some years ago who made a good deal on a
nearly full spool of 20AWG Tefzel wire.
He wondered if there was any prohibition
for using this wire for everything.
The answer was "no problem" . . . slightly
heavier but it fits all the 20AWG d-sub pins
and PIDG termials were no problem either.
He COULD populate the fuse block entirely
with 7A fuses or anything lower that wouldn't
nuisance trip.
That project would probably set any faithful
adherent to AC43-13 into fits of apoplexy
while in fact, except for a few ounces
more empty weight on the airplane, no
design goals for safety or operation were
being ignored . . . and he saved a goodly
bit of money on wire and time for having to
'optimize' each fuse/feeder decision.
