echristley(at)att.net Guest
Posted: Tue Aug 11, 2020 12:14 pm Post subject: Valid test for voltage regulator |
I got a regulator off of Amazon that matches the generator I'm adding. Wanted to test its exact set point to make sure I don't kill another LiFePO battery.
I connected an adjustable power supply to the two-prong input, and tracked the voltage between the single output lead and the aluminum case as I cranked up the supply. The output tracked the input all the way up and past the 14.7V advertised regulation point. At 20.5V, the limit of my supplies capability, there was 19.8V between the output lead and the regulator case. I added a light as a small load, and got the same results.
Would I embarrass myself for leaving a review that this is a regulator that doesn't regulate? Granted, the input expects an AC voltage, and I'm giving it DC, but shouldn't it still regulate the output to something close to the nominal voltage?
ceengland7(at)gmail.com Guest
Posted: Tue Aug 11, 2020 12:43 pm Post subject: Valid test for voltage regulator |
On 8/11/2020 3:09 PM, Ernest Christley wrote:
| Quote: | I got a regulator off of Amazon that matches the generator I'm adding. Wanted to test its exact set point to make sure I don't kill another LiFePO battery.
| Is it for a dynamo (PM alternator)? If yes, try hooking it up to something that *is* AC. Quick & dirty source might be an old school door bell transformer, or the transformer that powers older natural gas furnaces. Both are usually 24V AC.
If you look at some of the diagrams that have been posted recently for rectifier/regulators (ex: the Revmaster diagrams), some of them show one end of the dynamo winding tied directly to the DC bus.
Posted: Tue Aug 11, 2020 2:47 pm Post subject: Valid test for voltage regulator |
At 03:09 PM 8/11/2020, you wrote:
| Quote: | | I got a regulator off of Amazon that matches the generator I'm adding. Wanted to test its exact set point to make sure I don't kill another LiFePO battery. |
What brand/model of battery?
| Quote: | I connected an adjustable power supply to the two-prong input, and tracked the voltage between the single output lead and the aluminum case as I cranked up the supply. The output tracked the input all the way up and past the 14.7V advertised regulation point. At 20.5V, the limit of my supplies capability, there was 19.8V between the output lead and the regulator case. I added a light as a small load, and got the same results.
Would I embarrass myself for leaving a review that this is a regulator that doesn't regulate? Granted, the input expects an AC voltage, and I'm giving it DC, but shouldn't it still regulate the output to something close to the nominal voltage? |
The RECTIFIER/regulator is an AC driven
device. It turns ON by triggering a silicon
controlled rectifier which STAYS on until
the AC wave form passes through zero volts
at the end of the half-cycle.
It's unlikely that you're going to 'kill'
a battery with a in-situ test of this
regulator. It may prove to regulate
a bit higher or lower than optimum . . .
but if your battery features a BMS,
then 'optimum' is about a barn-door
wide.
Posted: Wed Aug 12, 2020 6:12 am Post subject: Valid test for voltage regulator |
I'm the one with the "Scorpion" battery. No BMS.
Well, I may be overstating the case. It does look like it has a network of connections to balance the cells. But there is no facility to remove the input voltage.
I'll rig up a way to mount the generator in the lathe this evening, and put the regulator in a more realistic test.
Charlie, I ohmed the leads out, and none of them seem to be tied directly to ground.
On Tuesday, August 11, 2020, 6:48:31 PM EDT, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
wide.
Posted: Wed Aug 12, 2020 9:14 am Post subject: Valid test for voltage regulator |
At 09:09 AM 8/12/2020, you wrote:
| Quote: | I'm the one with the "Scorpion" battery. No BMS.
connections to balance the cells. But there is no facility to remove the input voltage. |
That comports with other bare-foot lithium
offers I've seen. They bring out taps between
the stacks of cells to allow installation
of either (a) and external balance network
or (2) lithium specific battery chartger that
includes a balancing feature.
and put the regulator in a more realistic test. |
Sounds like a plan.
Photo-document your setup and share results!
