RG400 with RG58
Dan Fritz
PostPosted: Sat Aug 08, 2020 8:38 am    Post subject: RG400 with RG58 Reply with quote
When I started my Velocity build, I installed embedded antennas in the wings with RG58 also embedded from the wing root to the antennas. Now I need to complete the rest of the coax runs to the radios (about 12 additional feet). Is there any reason I can't use RG400 for this section of the cable, connecting the two with BNC connectors?
Dan
cbirdsall6(at)cox.net
PostPosted: Sat Aug 08, 2020 3:50 pm    Post subject: RG400 with RG58 Reply with quote
In short - that would work just fine.
The only caution I would add is that RG400 is slightly different in size than RG58. Make sure the connectors you use are compatible with the cable. A dual-crimp BNC designed for RG 58 may not fit on RG400 as 400 has dual (thus thicker) shielding. You won’t know this until you try to push the crimp ferrule into position prior to final crimp.
Chuck
Dan
http://forums.matronics.com/viewtopic.php?p=497584#497584
PostPosted: Sat Aug 08, 2020 4:59 pm    Post subject: RG400 with RG58 Reply with quote
At 06:46 PM 8/8/2020, you wrote:
--> AeroElectric-List message posted by: Chuck Birdsall <cbirdsall6(at)cox.net>
Both are nominally 0.195" diameter and use
the same connectors. The shield grip sleeve
is a bit harder to push over the RG400 shields
because there are 2 of them . . . but it will
go.
 Filesize:  30.5 KB
 Viewed:  4613 Time(s)
Dan Fritz
PostPosted: Sun Aug 09, 2020 9:20 am    Post subject: Re: RG400 with RG58 Reply with quote
Thanks very much for the help. Looks like I have a way forward.
Dan
