Double wall heat shrink for welding cable?
rparigoris
PostPosted: Fri Aug 28, 2020 11:05 am    Post subject: Double wall heat shrink for welding cable? Reply with quote
Hi Bob you wrote this on a replyand I don't understand it "I need to upgrade that article to suggest welding cable with double-wall heat shrink as opposed to the stiff-stuff"
I plan on using B&C #4 Super-Flex Battery Leads going from firewall to engine x2: https://bandc.com/product/super-flex-battery-lead-red-raw-material/ when you suggest using double wall heat shrink, are you suggesting to use double wall heat shrink tubing only at terminal lugs or for the entire length of the welding cable?? What type of heat shrink is your suggestion? Thx. Ron P.
