914 generator disconnected and running fuel pump #1
rparigoris
PostPosted: Wed Sep 16, 2020 7:57 pm    Post subject: 914 generator disconnected and running fuel pump #1 Reply with quote
Hi Group I have a curiosity question. If a 914 is wired as per Europa's schematic, if the battery is taken off line Fuel Pump #1 will run off the generator.
Question: Is there an RPM where the generator will not supply enough power to keep Fuel Pump #1 running?
In other words if on final with pump #1 running only on generator and you pull power will the engine quit?
Thx. Ron P.
