dpark
Posted: Wed Sep 16, 2020 11:45 am Post subject: Soft start |
I have just fitted two new soft start modules to my Rotax 912ULS. Should they both be activated by the start switch and start on both modules. or select only one module to start then activate the second by going to both. I have only wired up one module at the moment but have installed wire to be used from the second module if it is ok to do so.?
Any experts out there?
G-LDVO
Dave Park
_________________ Dave Park G-LDVO Europa XS Trike 912uls |
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Wed Sep 16, 2020 3:28 pm Post subject: Re: Soft start |
There will definitely be others with more in-depth knowledge than me to give you a solid engineering answer, but my experience leads me to suggest that if both your ignition systems are the same, then why not use them simultaneously to get your engine started?
If only one soft start module was fitted, then it would probably be wise to start using only that one to reduce the likelihood of the "kickbacks" such as ruined my first starter sprag clutch. That was when I had two earlier design ignition modules, but now that I have the current design of modules both incorporating a few seconds of ignition timing retardation, I start using both modules without hassles.
